problems with downloading flights from 302
Old September 3rd 10, 05:55 PM posted to rec.aviation.soaring
Nick Hill[_2_]
Default problems with downloading flights from 302
At 15:36 03 September 2010, Tim Newport-Peace wrote:
Validating traces is still a valid requirement so the tools to do so
need
to keep up with times.
Nick H
It has always been the case that older products have "Grandfathers
Rights". So there does not seem to be a way of forcing a manufacturer
to
change or update while the product conforms to the Specification as it
was when the product received approval.
Even then, if there was a legitimate case for making a manufacturer
change, the only weapon IGC has is the threat to withdraw approval, and
if IGC were to withdraw an approval, there would be a lot of squealing
from the users.
What would you have IGC do?
OK, valid points :-)
I should read the doc more closely before starting to type ....
I just checked the doc again and it does say
1) For new recorders the IGC Shell DLL option is mandatory
2) The provision of these Windows-based DLLs became mandatory on 1 July
2004. This is to allow for problems encountered running the non-Windows
'Short DOS programs' on some PCs.
3) For existing recorders it shall be produced by 1 July 2004
so it seems pretty clear.
As you say if a manufacturer doesn't comply for older exisitng recorders
then going down the route of withdrawing an approval isn't really
practical.
I just checked the IGC Shell and DLLsfrom the IGC web site on a 64-bit
Windows 7 system and it seems absolutely fine at validating traces,
presumably to be expected as it supports the Win32 APIs.
Nick H
problems with downloading flights from 302 Robert Holliday Soaring 15 September 16th 10 05:42 PM
Downloading GPS-NAV file to Ipaq Greg Arnold Soaring 3 June 27th 07 07:04 AM
Downloading CAI 10/20/25 file to Ipaq Greg Arnold Soaring 8 June 25th 07 12:19 AM
Downloading from AOPA Lou Home Built 3 November 14th 06 02:56 PM
Help downloading this site TripFarmer Owning 17 December 2nd 05 01:59 AM
