Gooney Bird control panel voltage?
Old September 6th 10, 08:07 PM posted to rec.aviation.homebuilt
pintlar
Default Gooney Bird control panel voltage?
Anyone know the voltage that is used for the instruments on a C-47 control
panel?
Specifically for the Artificial Horizon.
in advance, thanks. . .charlie
Old September 6th 10, 08:37 PM posted to rec.aviation.homebuilt
Dan[_12_]
panel?
That depends on which attitude indicator is used. Going from memory
here I believe the originals were vacuum. Since then DC indicators would
have been run off of DC bus and AC indicators would be 115 vac 400hz 3
phase. Then there were remote AI and ADI. One of the drawbacks to
aircraft that old and widely used is there have been many changes in
systems. I don't recall if USAAF/USAF and Navy aircraft even used the
same AI. I have seen USN and USAF aircraft of the same series with
different instruments for the same function.
To give you an idea what you are up against I used to work on T-33
instruments systems in the 1970s. The tech data covered several
variations in front and rear instrument panels. That's just the USAF
version.
If you have the part number or type designation a web search can
help. My personal experience when asking manufacturers for pin outs
usually results in "we will be happy to sell you a manual for $750."
Dan, U.S. Air Force, retired
Old September 7th 10, 03:57 AM posted to rec.aviation.homebuilt
rich[_2_]
Could be anything. I flew them for about 2500 hours, and the horizons
were vacuum powered. Any other electric ones could be whatever they
got approved and installed. Our DG's were vacuum also. Airspeed
indicators were direct reading gauges. The ones I flew were about half
ex-American airlines with the doors on the right side, and the others
were at one time Trans Texas Airways, later becoming Texas
International. Seems I remember the cockpit lighting was 24 volts.
The 3's pretty much pre-dated electric instruments.
Rich
On Mon, 6 Sep 2010 13:07:25 -0600, "Pintlar"
panel?
Gemini Artist concept of the Gemini spacecraft control panel S65-14095.jpg [email protected] Aviation Photos 0 April 9th 07 08:45 PM
Need pics of DC3 control panel please. Jim[_14_] Aviation Photos 3 March 7th 07 02:38 PM
Bird Control - Some Success Marco Leon Owning 9 July 21st 06 03:56 PM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 03:40 PM
