Info on strange linkage ?
Old September 20th 10, 05:01 PM posted to rec.aviation.soaring
Dave Nadler
Default Info on strange linkage ?
Does anybody have a drawing or picture of the
torsion linkage used to drive the ailerons in
early Ventus or the rudder in Libelle ?
Or can tell me what that's called ?
Thanks !
Best Regards, Dave
PS: It was used to avoid external bellcranks,
with their associated fairings and drag. It's
out of favor because it is problematic
(cost, weight, stiction, etc), and it turns
out the fairings add negligible drag...
Old September 20th 10, 07:06 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Thanks !
Best Regards, Dave
Dave,
No drawings or pix, &, I've no idea what it's called, but George Applebay used
the mechanism on Zunis, so he or Fidel at the shop might know...
Regards,
Bob W.
Old September 20th 10, 07:38 PM posted to rec.aviation.soaring
Berry[_2_]
Thanks !
Best Regards, Dave
Dave,
used
Regards,
Bob W.
Pictures of the rudder drive mechanism can be found on the Libelle Yahoo
group.
http://groups.yahoo.com/group/libellesailplanes/
You will probably have to join the group. The pictures are in the
"Photos" section under the heading H301 Rudder Linkage. Here's the url
direct to the pictures if it helps:
http://groups.yahoo.com/group/libell...m/294037972/pi
c/list
Seriously interesting mechanism. The kind of thing to keep one awake at
night trying to visualize how it works. Elegant, but fussy to get right
with bushings and shims. The aileron mechanism looks completely
different, but works the same way. No bushings or shims, though.
Old September 20th 10, 08:04 PM posted to rec.aviation.soaring
Lars Peder Hansen
It's called a Gimbal Drive. If anyone can tell more about it, it must be
Hansjörg Streifeneder at www.streifly.de
Lars Peder
"Bob Whelan" wrote in message
Thanks !
Best Regards, Dave
Dave,
used the mechanism on Zunis, so he or Fidel at the shop might know...
Regards,
Bob W.
Old September 20th 10, 08:33 PM posted to rec.aviation.soaring
Brad[_2_]
Thanks !
Best Regards, Dave
also called a skew drive..................we use it in a few places on
the HP-24, but it's a secret where...............I've said too much
already!
Brad
Old September 20th 10, 09:20 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Thanks !
Best Regards, Dave
Hi Dave, have sent you details off forum
Colin
Old September 21st 10, 12:23 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 20 Sep 2010 09:01:48 -0700, Dave Nadler wrote:
Does anybody have a drawing or picture of the torsion linkage used to
drive the ailerons in early Ventus or the rudder in Libelle ? Or can
I've been told that it was originally developed by Messerschmitt and was
used on the Bf-109.
The BGA call it a 'gimbal rudder drive' and I've heard it called a
'crossed gimbal drive'.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 21st 10, 01:27 PM posted to rec.aviation.soaring
NG[_2_]
On Sep 20, 4:20*pm, Ventus_a
Thanks !
Best Regards, Dave
Colin
Ventus_a
The torque tube on the Ventus-A is used to drive the flaps, pushrods
are used for spoilers and ailerons, though they are all mixed and
linked. Will send you details offline...
NG
Old September 23rd 10, 12:35 PM posted to rec.aviation.soaring
Dave Nadler
Default Info on strange linkage (aka skew drive or gimbal drive) ?
Thanks !
Best Regards, Dave
Big thanks, also from Jud for whom I asked
the question, to all those that sent info.
Mega-Thanks to:
Brad, who emailed pics of the Libelle
rudder drive,
Colin Bryan from NZ, who emailed pics of
the Ventus a/b aileron drive nicely exposed
in a damaged wing.
Honorable mention to
Stanislav Poslušný from Czech Republic,
who mailed pics of the 304's rudder drive.
The 304 was the last Glasflugel design,
and the HPH version is much improved -
painted nice bright red instead of drab
blue-gray ;-)
Thanks also to a couple of folks who
emailed pics of the control-circuit
schematic from the manual (but you
can't see the skew drive in that pic).
You guys are great !
Thanks again,
Rod end bearing for DG 200 aileron linkage JC Soaring 1 August 11th 10 03:14 PM
Broken fuel selector linkage J McKernan Owning 4 October 22nd 07 09:29 PM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
Piper nosewheel steering linkage Jeremy Lew Piloting 2 November 19th 03 03:17 PM
