Required rating for doing annual inspection
Old October 13th 10, 05:42 AM posted to rec.aviation.soaring
Mike Ziaskas
Default Required rating for doing annual inspection
Could someone tell me what FAA rating a mechanic must hold in the US
to do a annual inspection on an experimentally certified glider. TIA
Old October 13th 10, 06:21 AM posted to rec.aviation.soaring
SoaringXCellence
to do a annual inspection on an experimentally certified glider. *TIA
Mike,
AFAIK
If the glider is home-built and the original builder still owns the
glider, (s)he can do the annual inspection.
In all other cases, the mechanic must hold an airframe mechanic
certificate with Inspection Authorization (IA), however no Powerplant
rating is needed.
Old October 13th 10, 06:23 AM posted to rec.aviation.soaring
Darryl Ramm
A&P (IA not required unlike a certified glider) is required to sign
off. Who actually does the labor is up to you and your A&P.
Darryl
Old October 13th 10, 11:45 AM posted to rec.aviation.soaring
Mike,
Any glider in the Experimental catogory can have its yearly Condition
Inspection performed by any mechanic with the Airframe rating.
If the glider has an engine the mechanic would also need the
Powerplant rating.
As you know if it is an "Amateur Built" i.e. homebuilt glider, the
builder may qualify for a certificate that allows the bulider to
perform the Condition Inspection. This is the mis-named Repairman's
Certificate.
An Inspection Authorization, which is a seperate certificate from the
A&P, is needed only when conducting a Annual Inspection for a Type
Certificated aircraft, i.e. SGS-2-33 etc.
Robert J. Mudd
A&P , I.A.
Annual inspection? What's that? Agent Gibbs Piloting 0 June 30th 10 12:48 AM
Hughes 269 Annual Inspection Brien Rotorcraft 0 August 12th 08 03:09 AM
Transponder Inspection Not Required? Chip Bearden Soaring 14 May 8th 08 07:38 PM
PIK 20 D Annual Inspection [email protected] Soaring 3 September 26th 07 05:43 AM
2006 Annual Inspection -- Complete Jay Honeck Owning 12 March 31st 06 03:27 AM
