737-700
Old March 4th 04, 03:34 PM
louis
Default 737-700
Hi,
Recently I was in a 737-700 during my trip. I noticed that the
landing speed was quite high. Anyone know what the normal landing
speed is for this aircraft?
Also, I noticed that there was another way to slow down the aircraft
after touching down. Was it reverse thrust of the engines? I am
confused because reverse thrust would cause engine overheating (that
is, there would be no air flowing through the engine but pushed out by
the reverse pitch of the blades).
Louis
Old March 7th 04, 12:27 AM
CFLav8r
Three ways to slow a jetliner, wheel brakes, reverse thrust, and
ground spoilers on top of the wing.
The "blades" do not change pitch, the exhaust out the rear of the
engine is turned around by deflectors.
Bob Moore
ATP B-727 B-707
Actually you forgot the fourth and fifth way... 4: Drag, 5: Obstacles.
Capt. Dan
L10-A-Lemon, Diesel-9
Old March 10th 04, 01:52 AM
David Lesher
I'd always assumed the ground spoilers were to kill lift, thus making
the brakes much more effective. Do they make a sizeable direct
contribution as well?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old March 10th 04, 02:01 AM
Robert Moore
Well... I've certainly been able to steer Boeing Jetliners even
at taxi speeds by using the spoilers.
Bob Moore
Old March 10th 04, 03:45 PM
Tamas Feher
thrust, and ground spoilers on top of the wing.
Braking parachute
Runway end catching net
I wonder how Flight 1420 went off the runway end? Did they deploy the
braking chute?
Old March 4th 04, 05:11 PM
Andrew Crane
"louis" wrote in message
om...
Hi,
ROFL - this is a troll, right :-)
Regards
Andrew
Inweb Networks. Quality internet and telecoms services
Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk
E1 call share. 0800, 0845 and 0870 numbers - best rates. Resellers welcome
Old March 5th 04, 06:10 AM
John Hilt
On 4 Mar 2004 07:34:35 -0800 louis
wrote in news:rec.aviation.misc
110 - 150 knots air speed, depending on weight an flap setting.
The ground speed may seem high with no wind.
The CFM56 core air flow is not affected during fan air flow deflection
and reversal. Older models with JT8 engines reversed all the air using
bucket deflectors, without overheating. Compressor and fan blade pitch
can't be adjusted on jet engines, only stator blade angle of attack.
_/_/_/ -=jh=-
Old March 11th 04, 06:28 AM
pacplyer
(louis) wrote in message . com...
Hi,
Louis
Louis,
Lots of things can cause a high groundspeed at touchdown. Many
airlines use reduced flap settings (for mtc savings and x-winds) and
bug up to 20kts on top of the "normal speed" for things like wind
gusts and shears. Or you could have had a ten knot tailwind. A flaps
up procedure if they are jammed, can result in an approach speed of up
to 160 kts on some widebodies. Most engines now use the "cascade"
type-reverser (developed by a mechanic from Western Airlines,) as
opposed to old-style clamshell reverser doors (Alas, I really miss
those old midevil mousetraps...) Overheating due to bad airflow was a
problem in the P&W JT9D-70A. EGT would take off without warning in
reverse sometimes and the S/O was authorized to reach up and announce
that he was "Shuting down number X" engine to save the companys' five
million dollar engine. But new engines have better stall/surge
performance. About 140kts was a typical speed for the 737-200.
pacplyer
