Experimental Engine
Old November 26th 03, 09:51 PM
Paul Lee
Default Experimental Engine
A am near applying for an airworthiness on my project and
need to specify engine model. For many registered experimentals
I see AMA/EXPR as engine manufacturer and UNKNOWN ENG for model
even though the engine is standard aircraft engine.
Is it advisable to use that declaration? I use an electronic
ignition and non factory fuel system. So it is not a certified
engine.
SQ2000 canard project: www.abri.com/sq2000
Old November 27th 03, 05:49 PM
George A. Graham
When I filled out the paperwork, I always put the motor as a Mazda 13b.
However, when they post the data, it is "unknown".
I think that they don't know or care.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old November 27th 03, 11:13 PM
O-ring Seals
On 26 Nov 2003 13:51:09 -0800, (Paul Lee)
engine.
www.abri.com/sq2000
Paul,
To make it an experimental engine you will have to remove the original
data plate. Actually, you can just flip it over and stamp it with
something like "Paul's Experimental Engine, Seral Number XXXX". From
that time on, it will be an experimental engine. In the event that
you sell the engine, (or install it on a certificated airplane)
conformity with the original type certificate will have to be
established by someone before it can be returned to a non-experimental
status.
O-ring Seals
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Hi-performance endorsment with a experimental engine Paul Lee Home Built 15 September 11th 03 12:00 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
