AVIATIONTOOLBOX: plot GPS log
Old June 21st 04, 07:10 PM
Kyler Laird
Default AVIATIONTOOLBOX: plot GPS log
I needed a break this morning so I whipped up a trivial little script
to create a sectional image from GPS data.
https://aviationtoolbox.org/Members/...ools/trip_plot
It just barely works but it takes NMEA $GPRMC sentences and generates
a JPEG. I noticed that there are people who like to document their
flights in this way so I thought such a tool might be useful.
Lots of improvements to make to it but I need to get back to other
things right now.
Enjoy.
--kyler
Old July 1st 04, 01:43 AM
John Clonts
"Kyler Laird" wrote in message
news
things right now.
Enjoy.
Kyler,
I think that's a great idea! My suggestion would be to use as input some
format other than NMEA sentences though. My favorite would be of course
oziexplorer ".plt" file format-- but any format to which gpsbabel can
translate would be preferable over the NMEA (to which gpsbabel can NOT
translate AFAIK).
Thanks for your efforts!
Cheers,
John Clonts
Temple, Texas
Old July 5th 04, 01:09 AM
Kyler Laird
"John Clonts" writes:
Try it now.
--kyler
Old July 5th 04, 04:59 PM
John Clonts
Try it now.
--kyler
Excellent, thanks!!
John
Old July 8th 04, 03:09 PM
Kyler Laird
Excellent, thanks!!
O.k., so real Ozi files work. I appreciate knowing that. (I tested with
an NMEA file that I'd converted to .plt. BTW, GPSbabel *can* convert back
to NMEA sentences.)
Are there other commonly used formats? I've only made direct captures from
a GPS receiver so I don't have any experience with the various flavors but
GPSbabel sure does support a bunch. I'm hesitant to just enable all of
them because it looks like some might require extra parameters to be
specified. I'd rather enable just those that people want to use.
I'll also take requests for enhancements. I have a few in mind already.
Thank you.
--kyler
Old July 10th 04, 04:37 AM
John Clonts
Excellent, thanks!!
to NMEA sentences.)
It does? I've only used it through http://wayhoo.com/index/a/gpsbabel/. I
don't see NMEA in the options list-- am I missing something?
from
Enhancement to track-plot: have an option to produce the sectional chunk
WITHOUT the actual track.
Other enhancement: produce a sectional chunk given two airport id's.
Thank you.
--kyler
Cheers!
John
Old July 10th 04, 01:09 PM
Kyler Laird
to NMEA sentences.)
Yes. Get the real thing.
http://gpsbabel.sourceforge.net/
The file format is "nmea".
http://gpsbabel.sourceforge.net/capabilities.html
That's not an enhancement...that's the only way I can produce GeoTIFFs
right now. (I had it working that way for awhile.) I haven't gotten
to where I can modify an image (using PIL) and then put the geo data
back on it.
So this is useful? It's not much of a "plot" but I've enabled it.
Hmmm...we're getting into less plotting and more chunking. I can see
where you're headed. I'll try to build another tool for specifying
chunks easily.
--kyler
Old July 11th 04, 03:10 AM
John Clonts
with
back
to NMEA sentences.)
I
Ok.
back on it.
If I understand you correctly, the "TIFF" option does not produce geotiff
info, but does produce the graphical plot of the track. The "GeoTIFF
without plot" option produces the geotiff without the graphical plot. This
is indeed the "enhancement" I was talking about, thanks
I like having the sectional boundaries chosen to include the specified
track. The plot is not as important, as Oziexplorer does that part very
well.
chunks easily.
Where AM I headed?
I'm saying, give me the sectional whose boundaries are chosen to include the
specified airports, in a similar way as it works with the plot above.
Thanks Kyler!
Cheers,
John
AVIATIONTOOLBOX: automatic route selection Kyler Laird Instrument Flight Rules 19 October 22nd 04 07:02 PM
AVIATIONTOOLBOX: parsing FAA ATA-100 data Kyler Laird General Aviation 0 January 31st 04 06:12 AM
AVIATIONTOOLBOX: How do you like your maps stitched? Kyler Laird General Aviation 24 December 10th 03 04:10 AM
AVIATIONTOOLBOX: how I convert sectional maps to map chunks Kyler Laird General Aviation 2 December 4th 03 01:09 AM
Gov't Warns of al-Qaida Cargo Plane Plot Phil Calvert General Aviation 8 November 10th 03 02:36 AM
