gear doors
Old October 18th 10, 04:15 AM posted to rec.aviation.soaring
hoss
Default gear doors
Anybody have a set of gear doors for a Ventus CM that they would sale ?
Old October 19th 10, 11:38 AM posted to rec.aviation.soaring
Fish[_3_]
Default gear doors
Which side? I have whole glider if you are interested!!
Cheers
Mark
Old October 19th 10, 12:58 PM posted to rec.aviation.soaring
Derek C
Default gear doors
Cheers
Mark
What happened to the old ones? It is generally worth repairing
damaged doors.
Derek C
Old October 19th 10, 02:02 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default gear doors
On Tue, 19 Oct 2010 03:58:34 -0700, Derek C wrote:
Cheers
Mark
What happened to the old ones? It is generally worth repairing damaged
doors.
....and very easy to do with some glass tape, laminating epoxy and a
support form made from thin (1/16") ply or sheet alloy.
I did mine last winter. Laminated on enough glass tape to get the
original dimensions and thickness built up on the chewed front edges,
sanded that to shape and finished off with a layer of 1 oz glass cloth on
the outside. The light cloth wasn't strictly necessary but did give a
great finish.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 21st 10, 03:04 AM posted to rec.aviation.soaring
hoss
Default gear doors
Thanks for the replys, I have found a set of new gear doors.
Ken
Old October 21st 10, 03:06 AM posted to rec.aviation.soaring
hoss
Default gear doors
Cheers
Mark
What happened to the old ones? *It is generally worth repairing
damaged doors.
Derek C
LS-6 Gear Doors FOR SALE John Bojack[_2_] Soaring 0 May 5th 09 03:58 AM
sealing landing gear doors ...... Ron Gleason Soaring 11 April 23rd 09 03:43 PM
Got doors? Proton Fox Aviation Photos 4 June 27th 07 10:55 PM
hangar doors Tater Piloting 16 November 10th 06 05:30 AM
behind closed doors 5-BG Soaring 8 October 1st 06 03:51 AM
