Arcus Mass Balance / Control forces
Old October 22nd 10, 11:53 AM posted to rec.aviation.soaring
Peter F[_2_]
Default Arcus Mass Balance / Control forces
Hi All,
DG claim that the heavier controls on the DG1000 / 1001, compared to the
Duo are due to changes in the flutter requirements imposed on them by the
FAA. They claim that any new designs would have to meet these new
requirements and so the light control forces of the Duo would be unable to
be replicated in any new designs.
Schempp Hirth have a new design, the Arcus.
So...
Does the Arcus have the light controls of the Duo?
Does it meet the Flutter requirements of the FAA?
Are S-H just better at designing control systems than DG?
PF
(Not in a position to buy Duo / Arcus or DG1001, just curious!)
Old October 22nd 10, 01:28 PM posted to rec.aviation.soaring
Andreas Maurer
On Fri, 22 Oct 2010 10:53:10 +0000, Peter F
As usual, the DG marketing is lacking.
The cause for the seemingly lighter controls of the Duo Discus is
simply its extremely long stick und huge deflection angles.
Yes.
Obviously.
Nope... they simply just have better marketing... and a longer stick.
Andreas
Old October 22nd 10, 11:40 PM posted to rec.aviation.soaring
soarboy
Obviously.
Andreas
Goes to show you: Walk Softly and carry a Big Stick
Old October 23rd 10, 04:09 AM posted to rec.aviation.soaring
Barry[_4_]
Obviously.
Andreas
My experience is the controls are lighter on the Arcus vs the Duo
ARC
Old October 24th 10, 02:15 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
FAA.
Andreas
Doesn't having the correct length of stick count as "Better at designing
control systems"?
By biggest issue with the DG505 (And DG1000 is similar) is lack of pedal
adjustment in the rear
Kevin
Old October 22nd 10, 01:51 PM posted to rec.aviation.soaring
Dave Nadler
On Oct 22, 6:53*am, Peter F wrote:
Hi All,
FAA.
FAA has nothing to do with this. You mean EASA...
No.
So...
I haven't flown Arcus yet, but by reputation control forces are
a bit lighter than Duo.
Not sure but I believe Arcus has already received EASA certification.
Until you fly an Antares, you don't know what
a good control system with light forces is.
Try moving the stick on an Antares on the
ground sometime. Really.
PF
Ready to help you with an order for an Arcus Electric,
Old October 22nd 10, 02:19 PM posted to rec.aviation.soaring
Peter F[_2_]
At 12:51 22 October 2010, Dave Nadler wrote:
On Oct 22, 6:53=A0am, Peter F wrote:
Hi All,
FAA.
According to DG it was a stipulation by the FAA
http://www.dg-flugzeugbau.de/dg1000-flattern-e.html
It'll be a long wait, 2nd hand Arcus unlikely to be in my price bracket
'til 2030.
But there's always the change of a lottery win at odds of 14 million to 1
against
PF
Old October 24th 10, 04:21 AM posted to rec.aviation.soaring
ventus2[_2_]
Yes, but lets not limit that to just control systems. :-p
I think you may see some cross influence down the line with Lange and
Schempps, so that the difference in control force assumptions will be
negligible.
Chris
Old October 23rd 10, 08:08 AM posted to rec.aviation.soaring
Bruce Hoult
On Oct 22, 11:53*pm, Peter F wrote:
Hi All,
Duo
I've flown both a Duo (once) and DG1000 (frequently), but not back to
back. The DG1000 has heavy controls? In what universe? It's *far*
lighter than the Janus (especially!) and Twin Astirs we had before the
DG1000s.
Old October 23rd 10, 08:31 AM posted to rec.aviation.soaring
Derek C
Hi All,
Duo
DG1000s.
Heavier stick loads are better for ham fisted glider pilots. Schempp-
Hirth gliders typically have very light controls, especially the
Standard Cirrus. I personally like flying both the DG1000 and the Duo
Discus. The only issue I have with the handling of the DG1000 is the
stick mounted spring trimmer lever which doesn't work properly. I
won't even mention its carp (anag) retractable undercarriage. Oh
sorry, I just did!
Derek C
Arcus E (electric) first flight ! Dave Nadler Soaring 5 September 22nd 10 01:13 PM
Arcus - first impressions Andreas Maurer Soaring 1 July 7th 09 01:35 PM
Maiden flight of the Arcus Nick Olson[_2_] Soaring 30 April 21st 09 12:09 AM
[PICTURES] Arcus 1st flight fred Soaring 0 April 8th 09 06:38 PM
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 02:20 AM
