KI229 RMI failure - what could be the cause of this?
Old February 12th 05, 12:37 PM
Andy_R
Default KI229 RMI failure - what could be the cause of this?
"Peter" wrote in message
Hi,
I have a dual-needle RMI, the Honeywell/Bendix KI229.
The instrument has seen various failures over the 3 years I've had it
from new. Just the OBS not turning, just the needles not turning, the
whole lot gone. The instrument has been changed and also a 400Hz
inverter has been changed.
I now have an intermittent failure which always fixes itself once the
aircraft becomes airborne (but never on the ground) so it's probably
vibration related. The OBS does not turn but the needles work fine.
The RMI has its own 28V 400Hz inverter and the dealer reckons it is
that (again).
But surely the KI229 uses the synchro principle to rotate not just the
OBS but also both needles, and the same inverter's failure would
freeze the whole instrument?
The HSI, from which the RMI (I am told) gets the heading data) works
fine.
I am an electronics engineer but haven't got into avionics much; also
obtaining the schematics is a world-class challenge
Can anyone suggest where to look?
As an electronics engineer you've probably got a lot more idea than I have.
The only things I can think of that happen in the air but not on the ground
a
1. the engine alternator is running continually at a higher speed so there
is a decent 28v supply regardless of load.
2. the heater is on so any damp dries out
Anything more sophisticated is beyond me.
Rgds
Andy R
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 02:48 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
"System Failure Is Blamed In U.S. Downing Of British Jet" Mike Military Aviation 20 May 21st 04 06:39 PM
"Miserable Failure" and the biography of G.W.Bush Vicente Vazquez Military Aviation 3 December 8th 03 09:40 PM
In Flight Failure Charles Talleyrand Military Aviation 1 August 4th 03 05:25 AM
