Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Becker Transponder wanted
Old October 29th 10, 11:52 PM
Brian Du Rieu Brian Du Rieu is offline
Junior Member
First recorded activity by AviationBanter: Oct 2010
Default Becker Transponder wanted
Wanted to buy used Becker ATC 4401 Mode C transponder unit only. Would also consider altitude encoder ACK A-30 or similar.
Rgds,
Brian Du Rieu
Old February 15th 11, 10:38 AM
Elisa Jack Elisa Jack is offline
Junior Member
First recorded activity by AviationBanter: Feb 2011
Guess the guy does not still have that transponder after 6 months of questions. I'm probably going to get one of those units from $pruce. Hate to "byte the bullet," but there are lots of helicopters around here and I'd hate to run into one of `em.
Also - space behind the panel is limited and this unit will fit.
Percy in SE Bama
FS: Becker Transponder Fox Two Soaring 2 October 29th 10 11:55 PM
Becker transponder max operating altitude 5Z Soaring 10 September 22nd 06 06:56 PM
Becker Mode S Transponder product announcement Tim Mara Soaring 7 October 24th 05 04:50 AM
Becker 4404-1 Transponder Behaviour Ian Soaring 2 July 18th 05 04:22 PM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Home Built 0 August 6th 03 04:21 AM
