L-NAV problem
Old November 2nd 10, 07:18 PM posted to rec.aviation.soaring
Ron Gleason
Default L-NAV problem
The L-NAV in my new to me ASW20 is not functioning properly.
The unit will shut off and re-boot randomly. It does not happen every
flight, sometimes will happen only once and then stop and other times
it just continues to shut off and re-boot.
I am about to pull the unit and replace the internal battery. Any
other thoughts or actions?
I have put a new battery in the plane, voltage readings according to
the L-NAV and GPS NAV have always been north of 12.5 volts. I have
inspected the wiring nothing is obviously frayed or shorting out.
Thanks in advance
Ron Gleason
Old November 2nd 10, 08:21 PM posted to rec.aviation.soaring
The unit will shut off and re-boot randomly. *It does not happen every
I am about to pull the unit and replace the internal battery. *Any
the L-NAV and GPS NAV have always been north of 12.5 volts. *I have
Thanks in advance
*Ron Gleason
Check the condition of power connector in back of instrument, both
connector on wire and socket.
Good Luck
UH
ADF Problem Al[_2_] Owning 4 November 24th 07 01:24 PM
ADF Problem tony roberts Instrument Flight Rules 14 May 12th 04 03:59 AM
ADF Problem tony roberts Owning 13 May 12th 04 03:59 AM
Problem with this NG? Regnirps Military Aviation 10 April 29th 04 04:39 PM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 05:25 PM
