Cessna 172K Hawk XP startup procedure?
Old July 4th 03, 10:26 PM
Andrew Boyd
Default Cessna 172K Hawk XP startup procedure?
Tommi Raitio wrote:
starting the Continental IO-360-K engine
The TCM fuel injected engines are sweet, pleasant, docile
and simple to start, as opposed to the Lycoming fuel injection
which is simple cold but can be a miserable fire-prone bitch
to hot start.
The TCM fuel injection is simple:
cold: mixture rich, throttle 1/3, primer pump 8 seconds. Yes,
fuel will run out the bottom. No biggie. Then, prime as you
crank. Try not to hydraulic lock the cylinders with 100LL.
You can bend a con rod that way, believe it or not.
hot: mixture rich, throttle 1/2, primer pump as you crank.
No futzing with the mixture as you would with a Lycoming - it
stays full rich for every start.
ATP www.pittspecials.com
Cessna buyers in So. Cal. beware ! Bill Berle Aviation Marketplace 93 December 20th 04 03:17 PM
Cessna buyers in So. Cal. beware ! Bill Berle Home Built 73 June 25th 04 05:53 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 01:57 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
