a Li-Ion in a lead acid world.
Old November 12th 10, 05:14 AM posted to rec.aviation.soaring
brianDG303[_2_]
Default a Li-Ion in a lead acid world.
I’ve been experimenting around with Li-Ion batteries for a few months
now, just for fun, and thought I would pass on a few observations that
might be interesting. I only experimented with Li-Ions that had a
separate printed circuit board incorporated into each cell, and I was
not able to ignite these by any combination of overload, short
circuit, or charging abnormality. At low levels of abuse including
dead shorting, the battery would just shut down, but at some point the
PCB would fail and that was the end of the battery. I was able to get
a very impressive fire with a lot of smoke by blunt force trauma with
the conclusion that in the event of a Li-Ion fire the only survivable
option would be to jettison the canopy, and then maybe jump. But I
ended up deciding that the odds of a fire were quite low.
I flew most of the season with a 3.6 AH (measured, not claimed)
battery running either the transponder, the radio, or the PNA and one
issue that came up was that some electronics do not like voltage of
less than 10.8 volts and the Li-Ion discharge curve (which was 11.8 to
9 volts) is such that they may have viable amperage right down to 9
volts that becomes useless. The radio (Becker) went into survival
mode at low voltages while the PNA, running from a 12 volt car
adapter, was happy
Rather late in the game I discovered that there has been a development
in the battery world I hadn’t heard about- more capacity in the same
size Lead Acid battery case. My glider came with a UB12100, a 7.5 lb
10 amp hour battery. I was able to swap it up to a UB12120, an 8.5 lb
12 amp hour battery, same size. Now I am able to find the UB12150
battery, again a direct replacement for a very common sailplane
battery size, now approaching 10 lbs but with a capacity of 15 AH.
My end result is to trade up to the new 15 AH battery and rig the 3.6
AH Li-Ion as a reserve. I seem to pull about .8 amps now running
everything off the main battery, but there are back-up batteries in
the Vario and the PNA I can switch to, so the plan would be, in the
event of a low main battery, to switch to all the back-up batteries
and employ a conservation strategy.
The Li-Ion battery I ended up with is he
http://www.dinodirect.com/Super-9000...YSD-12900.html
You can just ignore the claimed 9000 mA rating. At .8 amp draw I get
just 3.6 Ah to shut down.
Hope it was worth the read,
Brian
How long does it take for phosphoric acid to dry? Michael Horowitz Home Built 1 May 19th 09 11:49 PM
Broken P lead? Jim Burns Piloting 16 October 27th 06 08:06 PM
US Glider Clubs Lead IGC-OLC World League! Doug Haluza Soaring 6 July 8th 06 06:16 AM
Car (Including Lead-acid Aircraft) and Deep Cycle Battery FAQ Bill Darden Home Built 0 April 17th 06 05:26 AM
And A Little Software Program Shall Lead Them...... :-) John Clonts Instrument Flight Rules 12 July 15th 03 10:06 PM
