Wing cleaner
Old July 5th 03, 03:46 PM
Viperdoc
Default Wing cleaner
Any advice on the best wing leading edge cleaner /bug remover? I've tried
Simple green, car wash detergent in a spray bottle, and PPC Wing Clean. Any
other suggestions?
Old July 5th 03, 06:47 PM
OSKI 3
We use Windex after every flite and it
seems to work fine. Paint is 2 years old
and holding up fine.
Bill O
Old July 6th 03, 04:34 PM
Windex will destroy your windshield. Within a year or so the ammonia
in it will turn the plexiglass so milky you can not see if facing into
the sun.
Had my $1000 lesson on what cleaners not to use.
John
Bill O
Old July 6th 03, 05:38 PM
karl gruber
Just plain old water is good to remove bugs. As long as the airplane is
reasonably waxed I just spray water on the leading edges and wait 5 minutes
for the bugs to soften up.
Then a little Lemon Pledge from the big cans at Costco, and they wipe right
off. Now these are just lowly Northwest bugs. I'm sure the Midwest bugs are
larger, meaner, nastier, and harder to remove!
Karl
Old July 5th 03, 07:22 PM
Dan Luke
Lemon Pledge. It leaves a slick film that bug guts can't stick to as well.
Dan
C172RG at BFM
Old July 5th 03, 08:45 PM
Doug Vetter
other suggestions?
FWIW,
1) Wash the edges thoroughly with soap and water.
2) Wax them with a silicone based wax (work smart, not hard - use an
orbital polisher...I got a nice 5" one from Walmart for like $25).
3) Clean it with a moist terricloth towel after EVERY flight.
4) Rewax as necessary.
For the windows, use Plexus. Goes on like Pledge (and even smells a bit
like it), but "dries" when you rub it on (doesn't smear like pledge) and
actually lasts more than one flight (unlike pledge).
If you do the prep, the regular cleanup is easy. Wait until the bugs
harden and it'll take 10 times as long.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Old July 6th 03, 01:52 AM
SeeAndAvoid
ProtectAll - sort of like ArmorAll, but, I'm told, safer and better.
Can be found at Walmart.
Chris
"Viperdoc" wrote in message
Any
other suggestions?
Old July 7th 03, 02:25 PM
Mark T. Mueller
Protect-All ROCKS!!! It uses Carnuba Wax in the formulation rather than
silicones, but still provides good UV protection, is easy to apply, and can
be used on all plastics.
I also use it on my Jeep before off-roading, makes it easier to get the mud
off...
YMMV
Mark
Tiger N1533R
"SeeAndAvoid" wrote in message
thlink.net...
Chris
tried
Any
other suggestions?
Old July 6th 03, 04:03 AM
Viperdoc
OK. Today I tried lemon pledge in the spray can on one wing, and PPC wing
cleaner on the other. The PPC was definitely better for taking off the bugs.
It may not provide any long lasting protection like Pledge might. I keep the
plane waxed pretty well with Race Glaze, and I'm a little concerned that the
strong surfactant in the PPC might also be taking off the wax.
Overall, the pledge in a spray can worked pretty well, but it seemed like
it might be a bit expensive in the long run. I saw an orange citrus Pledge
in the store today which came in a pump bottle and was cheaper, but wasn't
sure if it was the same stuff. Anyone have any luck with this?
Old July 6th 03, 04:48 AM
Mitch
Cheaper versions of Pledge a "Favor" furnature polish. Walmart has
another brand of furnature polish that is about the same stuff for about 85
cents/can.
Mitch
Osan’s 51st Fighter Wing to get its own coin Otis Willie Military Aviation 0 April 5th 04 10:44 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
