Bendix AD 76-07-12
Old July 15th 03, 02:16 AM
Jonathan Goodish
Default Bendix AD 76-07-12
I have a Bendix starter switch installed in my PA-28-181, and as far as
I can tell it is original. The aircraft was built in 1977 so it's close
enough to the effective date of the AD to make me want to investigate
whether the switch is affected by the AD or not. I read the AD and I
cannot figure out for sure whether my switch has the date code that
would exempt it from the AD.
On the body of the switch there are three lines, the first being the
serial number. The lines read as follows:
10-357xxxx-1
B
7611
I don't know whether the "7611" is the date code or whether it's
something else. Can anyone help?
JKG
Old July 15th 03, 06:01 PM
Ross Richardson
I would almost bet that 7611 is the 11th week of 1976 and there for a
date code.
10-357xxxx-1
B
7611
JKG
Old July 17th 03, 03:30 PM
MikeM
Almost all electronic or electrical components (particularly electromechanical
parts, switches, ics, capacitors, power resistors, etc have a 4 digit date code
YYMM, where YY is non-millenium year when made, and MM is the month.
For example, I just pulled two Signetics LF444CN ic chips out of my junkbox, and
one has "M9336" following the Signetics logo, and the other has "M8830"; which I
interpret as meaning that the first was made in the 36th week of 1993, and the
second was made in the 30th week of 1988.
Other chips dont have the M in front of the number, but the 4 digit date code is
very likely to be on most electronic parts...
MikeM
Skylane '1mm
Pacer '00z
Bendix drives. JDupre5762 Home Built 6 May 16th 04 01:23 PM
value of Bendix / King klx100 mah Aviation Marketplace 1 December 19th 03 03:19 AM
Bendix T12 D ADF Henning DE General Aviation 5 November 3rd 03 03:18 PM
T 12D Bendix ADF Henning DE Instrument Flight Rules 0 October 27th 03 09:03 PM
Bendix King GPS Updates Matthew Waugh Instrument Flight Rules 1 August 5th 03 06:11 PM
