Stopping a Tail Tank Drip
Old November 24th 10, 08:39 PM posted to rec.aviation.soaring
jcarlyle
Default Stopping a Tail Tank Drip
Need some advice for stopping a drip (once per 20 seconds) from a tail
tank. I’m aware of using Vaseline / Chapstick / beeswax on under wing
dump valves, but what about on a tail tank? How would you even reach
it to goop it up (the seat is way up a 8 mm tube)?
The tank in question is a 5.5 liter slip-in tank on an LS8. It hadn’t
dripped at all until last weekend, when the temperature was around 5 C
(no worry about freezing, I was ridge running). I didn’t check the
tension on the cable, so maybe the problem will go away when
reasonable soaring weather returns.
Any thoughts would be appreciated.
-John
Pawnee fuel tank vent drip Mike McCarron[_2_] Soaring 1 November 3rd 08 02:56 AM
LS6-b tail tank leak fix kirk.stant Soaring 2 August 19th 08 02:39 AM
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 02:33 AM
Ventus B tail tank add on Cliff Hilty Soaring 1 October 7th 04 04:53 PM
ASW20 tail tank mod goneill Soaring 4 February 21st 04 07:16 PM
