Wrong OLC Start/End time
Old November 29th 10, 05:17 PM posted to rec.aviation.soaring
Ramy
Default Wrong OLC Start/End time
Many may not realize that the start/end time they see in the OLC daily
results, flightbook etc is the logger on/off time, not takeoff/landing
times! The takeoff/landing time are only available in the flight
detail page. So pilots using the OLC flightbook as electronic logbook,
log erroneous time (unless they turn their logger on/off at takeoff/
landing).
Suprisingly, this was the way OLC display start/end times for years,
perhaps from the beginning. I reported to OLC and they promissed to
look at it.
This also brings another question: Is it still required to log time
using pencil in an official paper log book, or printouts from
electronic logbooks or spreadsheets are acceptable?
Ramy
Old November 29th 10, 06:44 PM posted to rec.aviation.soaring
Andy[_1_]
To the best of my knowledge there is no (US/FAA) requirement to log
flights in any form except that minimum flight experience required to
qualify for the current or any future flight. If you don't carry
passengers in a glider I know of no requirement to log any flights at
all (assuming a private rating or better).
I gave up keeping a paper log book for glider flights years ago, since
my BGA log book didn't have space for all the flight data I wanted to
record. All my flights are recorded in a database file and
substantiated by flight log records. Any required log endorsements,
such a flight reviews, appear in my traditional paper power log. The
power flight records in that log are updated about once a year from my
computer records. That update is usually triggered by a flight review
or by a flight test for a new rating. I'd like to get rid of the
power log too but I need a place for written endorsements and there
are still a few new ratings I'd like to earn.
Using a paper log as primary seems really crude and it's almost
impossible to retrieve the data required for a new rating
application. In contrast just a few key clicks in my electronic log
provides a screen full of all the required data.
Yes, dBase still lives!
Andy
Old November 29th 10, 07:51 PM posted to rec.aviation.soaring
Mike the Strike
qualify for the current or any future flight. *If you don't carry
record. *All my flights are recorded in a database file and
or by a flight test for a new rating. *I'd like to get rid of the
application. *In contrast just a few key clicks in my electronic log
Andy
....and Andy still uses VisiCalc!
Old November 29th 10, 08:18 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Andy
Isn't that older than the guys that developed Google?
email me)
Old November 29th 10, 08:27 PM posted to rec.aviation.soaring
Andy[_1_]
Not true, but I still have a working Beeb. It was that computer that
hosted my second generation glider log book. After that I gave up
coding the database application myself and went commercial.
Andy
Old November 29th 10, 09:50 PM posted to rec.aviation.soaring
Mike,
That's funny. However, in ther world of dBase, I personallly preferred R-Base.
"Mike the Strike" wrote in message ...
On Nov 29, 11:44 am, Andy wrote:
.... Snip ...
Andy
Old November 29th 10, 10:20 PM posted to rec.aviation.soaring
Grider Pirate
log erroneous time (unless they turn *their logger on/off at takeoff/
landing).
look at it.
Ramy
Some loggers record from when they are turned on, others (the 302A I
have, for example) buffer X amount of time, throwing away the oldest
datapoints until movement begins. The Cambridge also stops recording
shortly after the glider stops. I was trying to write a macro that
would detect significant movement, and when movement stops, (from a
raw .igc file). As it turns out, that's not all that difficult, but
what IS tough is determining the release altitude. After beating my
cranium against a brick wall for several hours, I decided that
entering the data for each flight into my Excel Logbook manually
wasn't such a PITA after all.
BTW, I actually MISS dBase!
Old November 29th 10, 11:10 PM posted to rec.aviation.soaring
Ramy
Ok, it is getting even more confusing. Based on analysis of multiple
olc flights I found that, depends on your logger and the method of
submiting (direct OLC claim vs SeeYou) your start time will be either:
1 - Your takeoff time (correct) - when using loggers such as 302.
2 - Your logger start time (could be very incorrect) - When using
loggers such as Winpilot with direct OLC claim form.
3 - Your release time - when submitting from SeeYou.
Similarly, your end time will be either landing or logger off, depend
on your logger.
Bottom line, unless you use logger such as 302 and always submit with
OLC direct claim form, your start/end time are incorrect.
Ramy
landing).
look at it.
Ramy
datapoints until movement begins. *The Cambridge also stops recording
shortly after the glider stops. *I was trying to write a macro that
raw .igc file). *As it turns out, that's not all that difficult, but
what IS tough is determining the release altitude. *After beating my
Old November 29th 10, 11:31 PM posted to rec.aviation.soaring
Andy[_1_]
Get a free copy of Cambridge Aero Explorer Plus. The easily generated
flight analysis includes a flight time record that can be used in your
log book.
BTW the 302 is not the only Cambridge that has intelligent logger
start/stop. The 20 and 25 also do this.
Wonder what the market is for 20 and 25 loggers. Did they get
condemned by RAS Court like the Volkslogger?
Andy
Old November 29th 10, 11:56 PM posted to rec.aviation.soaring
Tony[_5_]
Wonder what the market is for 20 and 25 loggers. *Did they get
not yet, haven't been a lot of them for sale lately
SR-71 61-7974, engine start - "61-7974 engine start, Jan 16, 1984, Ramstein AB, Scott R Wilson.jpg" 176.9 KBytes [email protected] Piloting 4 November 3rd 07 01:14 PM
At what age did you start logging time towards your first pilot license? Jim Logajan Piloting 61 October 26th 07 03:07 AM
Russian Air Force Woes - Time to start again? Peter Kemp Military Aviation 31 February 21st 04 02:10 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
