Diesel engines- forced induction, power-weight
Old December 6th 03, 06:32 PM
Jay
Default Diesel engines- forced induction, power-weight
From what I understand, the low power to weight ratio of diesel
engines has been the main limiting factor for their adoption into
small planes (and passenger cars for that matter). The reason for the
high weight as it was explained to me was that the high compression
used for an auto-ignition type engine required strong, and thus heavy
castings to withstand the pressures.
So these days you see diesels fitted with forced induction systems,
which apparently makes them more peppy (e.g. the 90hp VW 1.9L TDI).
But doesn't this more powerful charge being introduced by the forced
induction system, just require again, a heavier engine to withstand
the more powerful explosion? Or to put in in converse, if the same
engine could have withstood the more powerful charge, couldn't they
have built it lighter in the first place and used a conventional
induction system? For now lets ignore the altitude power
normalization aspect for aircraft operation.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 01:44 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
