Go Back   Home » AviationBanter forum » About this forum » About AviationBanter
15 foot tides in the Inside Passage to Alaska
Old December 7th 10, 09:41 PM
Dick Blizzard Dick Blizzard is offline
Junior Member
First recorded activity by AviationBanter: Dec 2010
Default 15 foot tides in the Inside Passage to Alaska
If you are cruising from Seattle to Southeast Alaska, you need to be aware of the problems created by the large tides and the currents that the changing tides create. I have done the 'Inside Passage' several times and I have learned this: South of Nanaimo, British Columbia you will be required to plan your transit of Dodd Narrows. Plan to arrive at Dodd Narrows 1/2 hour prior to slack tide. Your can go through the Narrows when the tide is high and changing to ebb (high slack) or you can go through when the tide is low and changing to flood (low slack). You will have about 20 minutes of slack tide and there will be lots of boats going through the narrows in both directions. It is about how the fast running currents affect your steering, not about the depth of the water. If you are the only boat waiting to go through, you have done something wrong. It is important to note, if you use the Canadian Governments published time table, you must adjust for daylight savings time - a one hour miscalculation will give you a wild ride.
If there is an interest in this challenge you can read more on my website. http://dickblizzard.blogspot.com the click on the feature 'Log of the Cumberland'.
The Seymour Narrows is next and I will make a post later.
ILS HKS 900 foot ceilings and VOR A MBO 1200 foot ceilings video [email protected] Instrument Flight Rules 1 May 26th 08 09:05 PM
ILS HKS 900 foot ceilings and VOR A MBO 1200 foot ceilings video Vinnie Yasay Piloting 0 May 26th 08 09:04 PM
Alaska Senator Supports User Fees For All EXCEPT Alaska Pilots Larry Dighera Piloting 9 August 4th 07 08:17 PM
SSA shoots itself in the foot again [email protected] Soaring 14 January 23rd 05 10:39 AM
need 2024 t3 5 foot by 12 foot .020 groundloop Home Built 2 August 22nd 03 05:29 PM
