Fuel Gauge reading Empty.
Old December 14th 10, 01:22 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Fuel Gauge reading Empty.
I checked out a fuel tank transmitter the other day.
Under an inspection panel, a single screw terminal connects a wire to
the guage from a rheostat hooked to a float. I clipped a test lead on
the transmitter terminal, and grounded the other end. The gauge read
FULL (as it should)
So the gauge was OK.
So I was all fired up to find another transmitter ($$$) when I ran into
an A&P.
He said, check the transmitter grounding first.
It took me a little while to see the value of the suggestion.
Then I realized: when a transmitter reads short, meaning tank full,
the indication can fail if the short isn't produced in the transmitter
OR the short doesn't get from the transmitter body, to the airframe.
Neat!
Brian W
Need a source for a Fuel Sight Gauge. Ebby Home Built 3 December 3rd 06 12:51 AM
Fuel Gauge Inop VFR Day Flyin'[email protected] Piloting 65 October 20th 05 04:52 AM
Cherokee Fuel Gauge Mike Spera Owning 6 July 15th 05 05:30 AM
Aerospace Logic Fuel Gauge Scott G. Owning 10 May 13th 04 10:07 PM
Jim Weir's Capacitive Fuel Gauge Dave Bowman Home Built 0 January 22nd 04 03:06 AM
