Pricing a '74 Archer
Old August 3rd 03, 05:32 AM
Mike Noel
Default Pricing a '74 Archer
I'm trying to decide what is a fair price for this aircraft. I looked at
the asking price of 74 Archers in Trade-a-Plane and saw prices ranging from
the high 40's to the high 50's. I used the TAP estimator and came up with
about 52K. This plane is in good condition in and out, has older avionics,
an autopilot, com/nav1is an old bendix unit that seems to barely work,
com/nav2 is a newer King unit that seems to work well, it has an ADF, mode
C xponder, 4 place intercom, a King DME, EGT, g meter, and the rest of the
stuff you would expect. It has marker beacons but they don't seem to work.
It has about 3100 hours TTAF and 1000 hrs since engine overhaul (service
limits).
The aircraft shows a bit of damage history a long time ago when it was
landed on the nose gear and some of the gear parts where replaced and a
motor mount piece straightened. Cylinder 1 has been oscillating in the 70
to 74 range ever since the overhaul. The other 3 Cylinders seem to run
around 76 to 78. Looks like a couple of reocurring AD's are coming due
soon, AD 96 12 07 (something about impulse couplings) and AD 98 02 08
(crankshaft corrosion check?). At 10,000 feet with I think only a little
wind the DME was indication about 118 knots flying towards the station and
about 114 in the opposite direction.
The owner had supposedly checked with a local salesman and was given the
impression it would sell for 70K. I think the salesman was perhaps a bit
misleading.
Anyone familiar with what is involved with these AD's? Does the performance
sound reasonable for a 74 Archer? Would a stable but lower reading on
cylinder 1 normally be a warning flag?
Does 52K sound like a reasonable price?
Old August 3rd 03, 12:03 PM
Bob Noel
In article , "Mike Noel"
from
with
about 52K.
The TAP estimator always seems high to me. It would estimate
my 140 at about $55,000.
avionics,
mode
work.
sounds like the avionics are crap.
limits).
service limit overhaul? blech.
old damage history is not too much of an issue. However, I'd still
get my A&P to look it over real good.
70
It sure looks to me that AD 98-02-08 is overdue.
and
sloooooow.
if it had working avionics
if it had all ADs complied with
if the engine overhaul wasn't to service limits (cheap bugger).
What else did the owner cheap out on?
misleading.
yep.
Does the
performance
no.
not to me.
too high because I'm suspicious of all the stuff that barely works,
slow performance, service limit overhaul, lack of ad compliance.
make sure you get a GOOD prepurchase from an A&P you trust.
Good luck
Bob Noel
Old August 3rd 03, 01:34 PM
Justin Case
Call your insurance carrier, they will have the wholesale price from
the book. Compare that with the TAP estimator and go from there. And
yes, the estimator always seems to be high, as does the pricing guide
AOPA has. Buy with your head, not your heart. That way you'll not
overpay.
On Sun, 03 Aug 2003 11:03:34 GMT, Bob Noel
from
with
about 52K.
avionics,
mode
work.
limits).
70
and
sloooooow.
misleading.
yep.
Does the
performance
no.
not to me.
Good luck
New Pricing David R Townend Home Built 0 January 2nd 05 03:20 AM
Looking for Archer Ben Aviation Marketplace 2 December 12th 04 05:18 PM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Charity Auction - Flight in a Piper Archer over Cambridge Charlie General Aviation 0 October 8th 03 09:50 AM
Piper Archer III or Cessna 172SP Dale Harwell Owning 10 July 15th 03 04:01 AM
