hangar fire extinguisher
Old August 10th 03, 01:34 AM
Default hangar fire extinguisher
I see a neighbor's hangar has two conventional fire extinguishers on
the wall. Not a bad idea, I'm sure. But for potential hangar fires are
halon still the best or are the conventional extinguishers just fine?
Old August 10th 03, 06:18 AM
JerryK
I would rather have a convential fire extinguisher. That would much better
if a pile of rags or paper or plabe caught on fire. Plus you can get a huge
convetional fire extinguisher for the cost of a tiny halon (or whatever the
replacement stuff is called) unit.
Old August 10th 03, 06:47 AM
Dave S
I may be out of the loop but I thought Halon was on the EPA's ****list..
From a cost-effectiveness standpoint, plain old dry chem ABC will work
fine for most of what you will come across. If you have anything that
involves magnesium, you might want a class D (metal) fire extinguishing
agent.
Dry chem can be corrosive if left sitting on a surface and it TASTES
like crap to get a mouthful of it (personal experience here) but if you
clean it off after things cool down, collateral damage in most
hydrocarbon fires can be minimized. If you have a fire in your radio
stack, the stack is likely toast anyways, but any use of Dry chem will
guarantee it.
Dave PPSEL
Old August 10th 03, 05:14 PM
G.R. Patterson III
It is. Nobody's making it anymore, but there are outfits that salvage Halon
from old extinguishers and other equipment and fill new containers with it.
That, of course, makes Halon extinguishers pretty expensive these days.
George Patterson
They say that nothing's certain except death and taxes. The thing is,
death doesn't get worse every time Congress goes into session.
Will Rogers
Old August 11th 03, 01:01 AM
Tom S.
"G.R. Patterson III" wrote in message
Halon
it.
The Citation jets use Halon 1211 pressurized to 600psi for their engine fire
extinguishing systems. I suspect other use the same chemical, but the EPA
will make it cost six times as much to recharge the systems. But, alas,
they're from the government and here to _help_ you.
Tom
The government consists of a gang of men exactly like you and me. They
have, taking one with another, no special talent for the business of
government; they have only a talent for getting and holding office. Their
principal device to that end is to search out groups who pant and pine
for something they can't get and to promise to give it to them. Nine times
out of ten that promise is worth nothing. The tenth time is made good by
looting A to satisfy B. In other words, government is a broker in pillage,
and every election is sort of an advance auction sale of stolen goods.
- H. L. Mencken
Old August 10th 03, 06:21 PM
Craig
Dave S wrote in message ...
It is and for most instances you can't get the bottles serviced
anymore, but it can be found.
agent.
Also helps to have a decent CO2 unit around. I've been at a friend's
hangar when there have been two engine start fires over the years.
The dry chemical unit made a hell of a mess and the user was able to
only put about 10% of it in the area of the fire because of a breeze
blowing. With the CO2, we could get right up on it and snuff it quick
enough that nothing even got scorched.
Clean-up with the dry chem was several hours and required pulling the
engine off and opening it up to make sure there was no internal
damage ( powder went up the intake and the air/oil separator).
Craig C.
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Military Aviation 0 April 6th 04 12:58 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Aviation Marketplace 0 April 6th 04 12:57 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 0 April 6th 04 12:57 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:57 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:56 AM
