Sport Pilot Glider Rating?
Old January 3rd 11, 01:53 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Default Sport Pilot Glider Rating?
Interesting question from a Sport Pilot today. Can a Sport Pilot do a glider add on? Would it be a Sport Glider Pilot license? I haven't heard of such an animal, any one know the answer? Thanks.
Walt
Old January 3rd 11, 12:14 PM posted to rec.aviation.soaring
Mike the Strike
On Jan 2, 8:53*pm, Walt Connelly Walt.Connelly.
Interesting question from a Sport Pilot today. *Can a Sport Pilot do a
glider add on? *Would it be a Sport Glider Pilot license? *I haven't
heard of such an animal, any one know the answer? *Thanks.
Walt
Walt Connelly
Apart from the restrictions on the type of aircraft (you would need to
find a Light Sport Glider), the altitude restrictions to 2,000 ft AGL
would make soaring a challenge!
Old January 3rd 11, 01:18 PM posted to rec.aviation.soaring
Leroy Tire[_2_]
I thought the restriction was 10,000 MSL?
On 1/3/2011 6:14 AM, Mike the Strike wrote:
On Jan 2, 8:53 pm, Walt ConnellyWalt.Connelly.
Walt
Walt Connelly
Old January 3rd 11, 01:48 PM posted to rec.aviation.soaring
vaughn[_3_]
"Mike the Strike" wrote in message
The biggest challenge is probably finding a soaring operation that understands
the Sport Pilot regs and is interested in using them to certify new glider
pilots. If you already have a Sport Pilot license, adding gliders takes the
appropriate training and signoffs by two instructors. Amazingly, it requires no
FAA written or flight test.
The Altitude restriction is 10,000 feet MSL. This can be an issue in some
higher parts of the country but usually not.
You must have flight and ground visibility of 3 miles. There may be days when
this requirement keeps you on the ground while others are flying.
You need to find a glider under 1,320 pounds gross, stall under 45 knots, and
Vne under 120 knots. That fits some existing training gliders.
Read Subpart J of Part 61 for the details.
Vaughn
Old January 3rd 11, 02:14 PM posted to rec.aviation.soaring
Tony V
Here's my cut at it -
http://home.comcast.net/~verhulst/GB...sportpilot.htm
Tony
Old January 3rd 11, 04:31 PM posted to rec.aviation.soaring
Brian[_1_]
Here's my cut at it -http://home.comcast.net/~verhulst/GBSC/student/sportpilot.htm
Tony
The biggest problem with the sport pilot glider certificate is there
is little incentive to get it over a private certifcate. As I recall
the training in nearly identical. One just has to take the Knowledge
test (I think) and find a DPE to take a practical test, instead of
with a CFI. Most soaring sites are already set up for this. This will
add a few hundred dollars and some additional study for the knowledge
test, but then one does not have the limitations of the Sport pilot
certificate.
Brian
Old January 3rd 11, 06:44 PM posted to rec.aviation.soaring
vaughn[_3_]
"Brian" wrote in message
certificate.
I agree with what you say. I would try to talk any new student into going for
the Private, but that wasn't the original question. The OP seemed to be asking
about a glider add-on to an existing Sport Pilot certificate. That is actually
a pretty simple thing for any glider school to do providing they have a suitable
trainer and two CFIG's.willing to sign.
Vaughn
Old January 3rd 11, 09:44 PM
Senior Member
Thanks for the info folks, I had never heard of such an animal and the SSA website does not mention it, only Private, Commercial and CFI-G ratings for gliders. Asked a CFI_G and he said it had never come up with a student.
Walt
Old January 4th 11, 12:09 PM posted to rec.aviation.soaring
Mike the Strike
certificate.
I agree with what you say. *I would try to talk any new student into going for
the Private, but that wasn't the original question. *The OP seemed to be asking
about a glider add-on to an existing Sport Pilot certificate. *That is actually
Vaughn
Except that the Sport certificate is only valid for flying light sport
aircraft. I am not aware that any two-seat LSA gliders exist.
Old January 4th 11, 06:59 PM
Senior Member
certificate.
Vaughn
I think most two seat gliders probably come in under the weight restriction for LS aircraft. No one at the gliderport I fly at has ever had anyone try to do this type of glider rating but apparently it can be done.
Walt
Adding an airplane rating to private pilot glider gmcd05 Soaring 35 April 25th 08 01:43 AM
Foreign Pilot Getting US Glider Rating Papa3 Soaring 10 April 16th 07 02:27 PM
Sport Pilot and Glider Questions Ralph Steiner Soaring 17 February 22nd 06 11:34 AM
endorsements for private pilot glider rating Joel Taylor Soaring 2 October 2nd 03 06:44 AM
Private Pilot Glider Rating Requirements John Soaring 8 August 21st 03 01:09 AM
