parallelogram stick
Old January 9th 11, 06:07 PM
Timinnc Timinnc is offline
Junior Member
First recorded activity by AviationBanter: Jan 2011
Default parallelogram stick
Sorry guys, can't find the answer via search, but what is a parallelogram stick?
Old January 9th 11, 07:59 PM posted to rec.aviation.soaring
Derek C
Timinnc
It is where the stick just moves backwards and forwards on a
parallelogram mechanism, as opposed to being bottom hinged. It's
supposed to stop pilots putting in unintentional movements due to g
loadings.
Derek C
Old January 9th 11, 10:49 PM posted to rec.aviation.soaring
SoaringXCellence
Timinc,
I have pictures of a parallelogram stick assembly if you'd like to see
them.
Contact me
c i r r u s c f i ( a t ) g m a i l . c o m
Old January 9th 11, 10:54 PM posted to rec.aviation.soaring
GM
Timinnc
Tim,
the elevator input is given by moving the stick back and forth on a
straight line rather than rotating the stick around one single hinge
point. To make matters worth, the commonly used sticks are typically
off-set from the hinge point towards the rear. High vertical
accelration can induce an unwanted elevator input. As Derek pointed
out, pilot induced oscillations due to vertical accelerations is not
an issue with these sticks. The Glassfluegel H303, H304 (incl. the CZ)
Mosquito and maybe other types have this type of stick.
Uli
Old January 10th 11, 12:36 AM posted to rec.aviation.soaring
brianDG303[_2_]
Timinnc
Tim,
Uli
Almost all, if not all, of the DG series gliders have them.
Old January 10th 11, 01:07 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Sun, 09 Jan 2011 16:36:39 -0800, brianDG303 wrote:
Timinnc
Tim,
out, pilot induced oscillations due to vertical accelerations is not an
Uli
DG 300 for sure, but not, IIRC the DG1000 and I seem to remember a
'normal' stick in the DG-500.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 10th 11, 02:20 AM posted to rec.aviation.soaring
On Jan 9, 5:07*pm, Martin Gregorie
Timinnc
Tim,
Uli
martin@ * | Martin Gregorie
org * * * |
DG1000 is "normal"
Kestrel's also had the parallelogram stick.
took very little time to get used to and was quite comfortable to fly
with.
Al
Old January 10th 11, 02:33 AM posted to rec.aviation.soaring
Bruce Hoult
On Jan 10, 7:07*am, Timinnc
This is one, in a Club Libelle.
http://farm3.static.flickr.com/2746/...cb753ae4_b.jpg
Sorry if it's not too clear but I wasn't especially taking a photo of
the stick!
The stick grip is on a vertical shaft that comes down only as far as
the horizontal tube, to which it is rigidly welded. There are two
pivoting vertical tubes coming down from the middle and front of the
horizontal tube. The front one is obscured by the foam.
Old January 10th 11, 02:38 AM posted to rec.aviation.soaring
ContestID67[_2_]
I was told that the parallelogram stick was to prevent PIO. Is that
the same as "unintentional movements due to g loadings"?
I have flow a DG-101G, DG-300 and DG-303 with a parallelogram stick.
I also fly an assortment of ships without a parallelogram stick.
Honestly, I don't know if I have noticed much of a difference.
However, the DG (with parallelogram) has a CG release while the others
(non-parallelogram) do not. Would a parallelogram stick help prevent
ballooning (with ugly consequences). If so, I am all for it.
- John
Old January 10th 11, 08:55 AM posted to rec.aviation.soaring
Derek C
On Jan 10, 1:07*am, Martin Gregorie
Timinnc
Tim,
Uli
org * * * |- Hide quoted text -
- Show quoted text -
We have a DG300 fitted with a parallelogram stick based at our site.
It seems to be more prone to pilot induced oscillations on aerotow
than most!
Derek C
Dead Stick Big John Piloting 18 August 3rd 08 04:25 AM
Big Stick R. J. \(Bob\) Van Horn Piloting 5 September 4th 07 06:54 PM
Stick on Bi-focals MC Soaring 0 December 6th 04 03:24 AM
The F-16 control stick? Christopher Military Aviation 13 September 22nd 03 10:18 AM
Stick grips John Nicholson Home Built 17 July 23rd 03 10:13 AM
