LK8000 v2.0 released today
Old January 15th 11, 04:03 PM posted to rec.aviation.soaring
PCool
Default LK8000 v2.0 released today
I am pleased to announce that the opensource and free software LK8000 v.2.0 was released today.
It is now translated into 14 languages.
paolo
Old January 15th 11, 06:13 PM posted to rec.aviation.soaring
kirk.stant
On Jan 15, 10:03*am, "PCool" wrote:
I am pleased to announce that the opensource and free software LK8000 v.2..0 *was released today.
paolo
Just curious, can LK8000 run on an Oudie?
Kirk
66
Old January 15th 11, 06:18 PM posted to rec.aviation.soaring
SoaringXCellence
Yes, if you can boot off the SD card. The OS (Windows CE) is supported.
Old January 15th 11, 07:59 PM posted to rec.aviation.soaring
mike
paolo
Very nice Paolo. Thank you for your great effort.
Old January 15th 11, 08:38 PM posted to rec.aviation.soaring
tstock
I am pleased to announce that the opensource and free software LK8000 v..2.0 *was released today.
paolo
I have been using this for awhile on an old nokia navigator, but I
need something with better battery life, and USB for condor. Anyone
have any suggestions?
Thanks
Old January 18th 11, 02:32 AM posted to rec.aviation.soaring
Brad[_2_]
paolo
ok, so I am looking for the installation instructions so I can stop
seeing the fatal error 001 code and start seeing the program. no links
for the manual, at least that I can find, and no description on how to
install other than read the manual..............so I am in a quandary.
of course, the info is probably right in front of me but I don't see
it.
help!
Brad
Old January 18th 11, 12:15 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
of course, the info is probably right in front of me but I don't see it.
Unzip it onto an empty SD card, copy your airspace, map (.LKM + .DEM) and
turnpoint files into the appropriate subdirectories. Add your polar file
if you use a one. Set up the launch system as you did for the previous
version: Binatone B.350s need a 'shell.ini' file in the root of the SD
card to tell WM 5 or 6 where to find LK8000. This should run OK.
*DON'T* copy over your old task and profile files because both file
formats have changed. The release notes mention that the task file format
has changed, but say nothing about the profiles. I initially copied mine
over and got a crash during start-up. I'd wondered if copying the
profiles was a good idea, so I restored the ones that were in the 2.0a
zip file and this time it 'just ran'.
The only snaggettes I've found a
- configuration: it defaults to metric units, so select the files on
page 1 and then go immediately to the Units page, select feet,
knots, etc. and then immediately exit config, shut down and restart.
If you don't restart at that point you'll find that its still
expecting safety heights, etc to be input in metric values.
- custom overlay colours: If, like me, you fly with terrain turned off
and a white background for maximum contrast, set 'Inverse b/w' ON and
'overlay colours' to WHITE, but leave 'Turnpoint labels' set to BLACK.
If you set the turnpoint labels to white as well, turnpoints marked as
Airfields will appear as white with a black border though the rest will
be plain black.
- finding the GPS device: my Binatone came up with both devices set to
COM1 and so LK8000 reported that no GPS was found until I manually set
the devices to COM7.
Another way is to unzip it into the C:\ drive, add files as described
above and then run up LK8000-PC.EXE in sim mode, configure this as you
like it and then copy the LK8000 directory and all its contents to a
blank SD card. This will leave everything (except possibly the GPS ports)
set correctly.
I like having the sim functions rolled into the main LK8000 program -
that was a good move.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 18th 11, 04:35 PM posted to rec.aviation.soaring
PCool
Well this is really interesting, at least for me.
What's difficult in looking into www.lk8000.it and the download section?
See the download menu: maps, manual, software...
Manuals!
The fatal error is given because you have not installed the software
correctly, probably in the wrong directory.
But on the same fatal error screen, you can also clearly read what the
program is trying to access, the full path.
That's the place, of course.
So the question is: where have you been looking for manuals so far?
paolo
"Brad" ha scritto nel messaggio
paolo
it.
help!
Brad
Old January 18th 11, 05:15 PM posted to rec.aviation.soaring
On Tue, 18 Jan 2011 16:35:25 +0000, PCool wrote:
Well this is really interesting, at least for me. What's difficult in
looking into www.lk8000.it and the download section? See the download
menu: maps, manual, software... Manuals!
Paolo,
Just to clarify: does the 1.22 manual, which is what I see on the manual
page, also apply to 2.0?
org |
Old January 18th 11, 06:17 PM posted to rec.aviation.soaring
PCool
The latest available version is 1.22b manual, as written on the download
page.
The install procedure is the same. But even in doubts, when nothing else
better is available, why not looking into the available manual release 5
months ago?
Other gliding software have a manual obsoleted by years..
The web pages have now explanation about new 2.0 features, while I am
updating the 2.0 doc.
"Martin Gregorie" ha scritto nel messaggio
Paolo,
org |
iPAQ-310-LK8000-wind calculation Brad[_2_] Soaring 6 September 7th 10 11:05 PM
The LK8000 copyright issue is solved Max Kellermann Soaring 5 September 7th 10 06:50 PM
LK8000 questions Andy[_1_] Soaring 9 March 15th 10 11:10 AM
New LK8000 glide computer video PCool Soaring 6 October 12th 09 06:19 PM
T-37 PCATD released JD Simulators 0 October 6th 03 08:51 PM
