UPDATED - Overhaul time....
Old August 19th 03, 08:29 PM
Dennis O'Connor
Default UPDATED - Overhaul time....
BTW, due to cross firing of the prefrontal lobes I kept calling the Unison
LASAR ignition system the SlickStart... Slick Start is their solid state
'shower of sparks' box that can be added to most any magneto system for
improved starting... About $300.. I have flown a plane with one and it
worked as advertised... Hot fuel injected Lycoming and it fired before the
second blade..
The system I described was the LASAR electronic magnetos/ignition... Works
like a bandit... The last plane I helped time the magnetos on was an upgrade
from the Slick Start to the LASAR... I have not flown this plane but I did
help with the installation and getting it running on the ramp... If I
decide to upgrade the engines on the Apache, this system is on the short
list...
Denny
Old August 20th 03, 02:01 AM
Doug
I saw these systems at Oshkosh. I have an Aviat Husky A-1 with
carbureted Lycoming 0-360 with Slick Mags. One question, can I hand
prop with the "shower of sparks" box? I am interested in it because I
have floats (summers) and when you push away from the dock, you HAVE
to start. I occasionally have reluctant (usually HOT) starts. New
plugs seem to help. I am getting tired of replacing the plugs every
250 hours (or cleaning). Anyone know about "fine wire" plugs? Anyway,
these are the issues I still don't understand.
"Dennis O'Connor" wrote in message ...
second blade..
list...
Denny
FS: 2002 "Ghosts: A Time Remembered" (Aviation) Calendar J.R. Sinclair Military Aviation 0 June 14th 04 06:22 AM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 03:33 AM
GWB and the Air Guard JD Military Aviation 77 March 17th 04 10:52 AM
Russian Air Force Woes - Time to start again? Peter Kemp Military Aviation 31 February 21st 04 02:10 AM
It's that time of year again. Capt. Doug Home Built 19 September 3rd 03 10:53 PM
