Wiring KDR-510
Old September 14th 03, 01:28 PM
Chad Lemmen
Default Wiring KDR-510
Why does the KDR-510 datalink receiver use two input wires for power and
two for ground? The schematic looks like this
KDR-510
3A
10-30 VDC---()-------------Power positive 1
\------------Power positive 2
Ground-------------|-------Power ground 1
|-------Power ground 2
Is the power positive 2 and power ground 2 wires just for redundancy?
I've never seen any avionics that use two wires both for power and ground.
Do both 1 and 2 need to be hooked up or just power and ground 1?
Old September 14th 03, 10:33 PM
David Dyer-Bennet
Chad Lemmen writes:
KDR-510
3A
I've seen this used in computer wiring where more power is needed on
"one" lead than on the others. This lets them use a smaller connector
(with one or two additional pins). Power and ground are the things
that's likely to be the issue for with avionics, so maybe that's the
purpose?
David Dyer-Bennet, , www.dd-b.net/dd-b/
RKBA: noguns-nomoney.com www.dd-b.net/carry/
Photos: dd-b.lighthunters.net Snapshots: www.dd-b.net/dd-b/SnapshotAlbum/
Dragaera mailing lists: dragaera.info/
Old September 15th 03, 03:08 AM
Aaron Coolidge
Chad Lemmen wrote:
: Why does the KDR-510 datalink receiver use two input wires for power and
: two for ground? The schematic looks like this
snip
: Is the power positive 2 and power ground 2 wires just for redundancy?
: I've never seen any avionics that use two wires both for power and ground.
: Do both 1 and 2 need to be hooked up or just power and ground 1?
Chad, the King equip I have (KX-155, KN-62) also have 2 pins each for power
and ground. These pins are connected together internally in both units.
They are hooked up using 22ga wire, so I suspect that some limit on current
in a 22ga wire is exceeded with a single wire. I would hook up both pins.
Aaron Coolidge (N9376J)
Old September 16th 03, 02:03 PM
Javier Gorordo
I use a rule o'thumb of 5 amps for 22 awg and 7 amps for 20 awg (tefzel or
equiv.)
The double power lead method bothers me because if one of the wires broke,
the equipment might then try to pull a full load thru a single (undersized)
wire...unless there is some special circuitry inside the box that prevents
that. Same thing for grounds...
"Aaron Coolidge" wrote in message
snip
ground.
power
current
Wiring KX 175 TSO Tore B. General Aviation 0 May 6th 04 10:02 PM
King KMA-26 Wiring Diagram Keith Dobbins General Aviation 0 August 23rd 03 04:03 AM
wiring diagram requests Rick Pellicciotti Home Built 2 August 5th 03 02:39 PM
Kawasaki TA-440 2B wiring diagram. jackthepilot Home Built 1 August 4th 03 06:33 PM
Narco AT-50A Wiring Diagram Needed Jerry Aviation Marketplace 0 August 3rd 03 11:07 PM
