Compaq Aero 1500 Question
Old March 27th 11, 06:23 PM posted to rec.aviation.soaring
Default Compaq Aero 1500 Question
I've been unable to get any tech assistance on these PDA's which I use
in the cockpit. The question I'd like help on is in regard to charging
them . When placing them in the cradle for charging the amber light at
top blinks for just a couple of seconds then goes off . What does this
indicate ? Should the light remain on when fully charged or go off as
it does? Thanks for any help .
ZA
Old March 27th 11, 06:34 PM posted to rec.aviation.soaring
WR
indicate ? *Should the light remain on when fully charged or go off as
ZA
Light should stay on. Mine does the same thing occasionally. Check
the power level screen, both main and backup battery should show
100%. Usually when the light blinks and goes off the main battery
will not register at all when you check it. Removing the cover and
moving the main battery around a little usuallly solves the problem
for me. The price we pay for using these relics.
WR
Used Compaq Aero 1500 units available Paul Remde Soaring 2 September 21st 10 05:50 PM
Wanted Power/data connectors for Compaq Aero 1500 PDAs Paul Remde Soaring 3 April 16th 10 01:23 AM
Seeking Compaq Aero 1500 Pocket PCs Paul Remde Soaring 0 March 25th 10 09:02 PM
Serial Connector for Compaq Aero 1500 series [email protected] Soaring 1 April 16th 05 02:58 PM
Compaq Aero 1500 Cradle PENN2P Soaring 1 October 18th 04 06:04 PM
