WTB: Tailwheel Cavity for Glider Trailer
Old March 30th 11, 07:04 AM posted to rec.aviation.soaring
Default WTB: Tailwheel Cavity for Glider Trailer
Anybody got a junk trailer with a fiberglass Tailwheel cavity/recess/
holder they'd be willing to part with?
Thanks in advance
Bryce
Old March 30th 11, 01:38 PM posted to rec.aviation.soaring
Guy Byars[_2_]
On Mar 30, 2:04*am, "
Thanks in advance
Bryce
They have them at the Cobra Trailer website:
http://www.cobratrailer.com/catalog/...products_id=70
Old March 30th 11, 05:32 PM posted to rec.aviation.soaring
I almost clicked checkout on one of these.....and then I realized how
comical this shiny and perfectly engineered Cobra part would look
against the backdrop of my glider and trailer. It would be like
putting a Ferrari seat in a dump truck.
All joking aside thanks for the input.....just seemed a little
overkill.
Bryce
Old March 30th 11, 06:58 PM posted to rec.aviation.soaring
Guy Byars[_2_]
Ok, how about this:
1) Cut hole in trailer under tailwheel
2) Cover rear fuslage and tail wheel area in plastic food wrap
3) Lay several layers of fiberglass cloth & resin over the hole in
trailer
4) Lower plastic covered tailwheel onto the wet cloth letting it push
down in the hole.
5) Block the tail up at the correct height.
6) Let the glass cure, trim, paint and attach with pop rivets.
The result should be worthy of any dump truck.
On Mar 30, 12:32*pm, "
overkill.
Bryce
Old March 31st 11, 02:11 AM posted to rec.aviation.soaring
On Mar 30, 1:58*pm, Guy Byars wrote:
Ok, how about this:
1) *Cut hole in trailer under tailwheel
2) *Cover rear fuslage and tail wheel area in plastic food wrap
3) *Lay several layers of fiberglass cloth & resin over the hole in
trailer
4) *Lower plastic covered tailwheel onto the wet cloth letting it push
down in the hole.
5) *Block the tail up at the correct height.
6) *Let the glass cure, trim, paint and attach with pop rivets.
overkill.
Bryce- Hide quoted text -
- Show quoted text -
Or make a plug the shape of the cavity out of wood. sand smooth and
fasten to smooth surface. Wax the heck out of it.
Lay up glass and resin. Trim when cured. If you use epoxy you can just
make the plug out of pink insulating foam and melt it out of the part
when done.
It should look home made enough to match your trailer.
FWIW
UH
Old March 31st 11, 08:58 AM posted to rec.aviation.soaring
One of the Zuni medicine men had a spare one out of an old trailer so
it looks like I'm in good shape.....now its more like a vintage
Ferrari tail light on a dump truck. This trailer is so ugly it looks
like a spanish freight airplane I used to fly.......
Thanks for the input guys......and thanks to Bob W. for the part.
Bryce
Old April 2nd 11, 01:56 AM posted to rec.aviation.soaring
Dick[_3_]
On Mar 30, 1:04*am, "
Thanks in advance
Bryce
As a matter of fact I have an original equipment Cobra trailer tail
wheel dock. It hasnt even been drilledfor attachment screws. Make me
an offer. Bidding starts at $10,000.
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
F.S. 3-glider trailer Nigel Pocock Soaring 0 September 29th 06 11:29 AM
glider trailer Q Ken Ward Soaring 10 August 28th 06 04:27 PM
glider trailer Q Steve Leonard Soaring 1 August 28th 06 05:29 AM
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel phillip9 Aviation Marketplace 0 June 6th 06 07:57 PM
