"High Temp" Tape?
Old April 10th 11, 01:57 PM posted to rec.aviation.soaring
Blue Whale
Default "High Temp" Tape?
Is there a tape out there for sealing gaps on metal sailplanes that
doesn't turn into a sticky mess after exposure to the sun and heat?
Would be nice to have a somewhat permanent solution that only needs to
be replaced a few times a year on gliders that sit outside assembled
for the season.
Old April 10th 11, 03:25 PM posted to rec.aviation.soaring
Mike[_28_]
There are high temp tapes available at Home Depot. They're not very
attractive but probably functional. I used muffler tape to do a repair
on my cars plastic heater housing and that has stuck pretty well. You
get the added bonus of highly reflective tape as an anti-collision
marker ;-)
Old April 10th 11, 05:21 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I sell a lot of Bowlus tape (and some 3M tape) to glider pilots - and to
owners of light-sport aircraft. It is used in some very hot locations. I
haven't heard any complaints about it not holding up in hot whether. You
can see details he
http://www.cumulus-soaring.com/bowlus.htm
http://www.cumulus-soaring.com/mmm.htm
http://www.cumulus-soaring.com/tape.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Blue Whale" wrote in message
for the season.
Old April 11th 11, 05:58 PM posted to rec.aviation.soaring
Grider Pirate
On Apr 10, 9:21*am, "Paul Remde" wrote:
Hi,
owners of light-sport aircraft. *It is used in some very hot locations. *I
haven't heard any complaints about it not holding up in hot whether. *You
can see details hehttp://www.cumulus-soaring.com/bowlu...g.com/tape.htm
Best Regards,
Paul Remde
for the season.- Hide quoted text -
- Show quoted text -
I fly out of Jean, NV. It does indeed get pretty hot here. One of our
members uses the Bowlus tape on his 1-35 'Iron Butterfly'. This
glider spends 365 days a year tied out in the weather, and the Bowlus
tape is the least problematic we've found so far. At that, I usually
help remove it, and it takes around 45 minutes with 3M General
Adhesive Cleaner and a rag to get all the old tape and residue off,
before re-taping. I also use the Bowlus tape for my pampered glass
ship that almost never gets tied out. The Bowlus has less tendency to
'creep' in hot conditions than any other tape I've tried, and I've
tried many types.
Old April 12th 11, 04:48 AM posted to rec.aviation.soaring
Frank Whiteley
Hi,
can see details hehttp://www.cumulus-soaring.com/bowlu...ulus-soaring.c...
Best Regards,
Paul Remde
I fly out of Jean, NV. It does indeed get pretty hot here. *One of our
members uses the Bowlus tape on his 1-35 'Iron Butterfly'. *This
tape is the least problematic we've found so far. *At that, I usually
tried many types.
No interest, just a good product for removing tape and other residues.
http://www.goofoffstainremover.com/w...n/tape-residue
Frank Whiteley
Cherokee 140 High Oil Temp. Update Mike Spera[_2_] Owning 3 June 30th 10 03:24 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 Saturn V with boilerplate spacecraft during transfer move from High Bay 2 to High Bay 3 ap13-KSC-69P-683.jpg" yEnc (1/1) [121K] hielan' laddie Aviation Photos 0 September 12th 08 03:17 PM
High Temp RTV on Exhaust Gaskets John Home Built 6 December 16th 06 10:25 PM
Low oil pressure, high oil temp? Roy Smith Owning 9 October 3rd 04 11:02 PM
Archer high oil temp Mike Noel Owning 7 June 15th 04 03:38 PM
