Blue Ridge Crash
Old April 15th 11, 04:59 AM posted to rec.aviation.soaring
Nick Kennedy
Default Blue Ridge Crash
A long time ago I visited a soaring site in Israel. The signal the
glider pilots used to signal readiness to the tow pilot was not waving
the rudder like in the USA, but opening and closing the
spoilers/breaks twice.
I was told one of the reasons for this was to make sure they were
closed on TO.
Roberto Waltman
This above post by Mr Waltman makes alot of sense to me and I would like
to see this procedure looked at closely. I am also a big fan of launching
with the spoilers open and have been doing it now for several years with
good results. Another thing I have trained myself to do is; When the
towplane / glider unit gets airborne and is in a steady state of climb, I
glance out to the left wing and look at the spoilers. It is easy to do
and your focus distance does not change much.
Another big issue for me is what really caused this accident, it sounds
like the rope or weak link broke. I don't think the rope should come
apart on a guy just because he has his spoilers out and the tow is slowly
progressing.
I've taken off in Parowan in my ASW-20 full of water with the spoilers
unlocked. I didn't think much of it untill the tow pilot called and
remarked about all the sink we were flying through!
We all make mistakes.
If the tug cannot climb and has to turn the glider loose, so be it. if
the tow starts going squirrily and the tow pilot is getting scared, turn
the glider loose. But it should be a decision made by the pilots, not a
P.O.S. rope break. Further more I think we need to all be using High
Quality ropes and weak links, and give up on that polypro.
The poly pro comes unthreaded,untied, it is EASILY damaged, it looks like
hell after only a few tows.
Look on the Wings and Wheels web page and look at the rope TOST puts out
and the Dacron Rope. Here in Telluride we ONLY use Dacron ropes because
they are reliable. If you have a rope break here, early on the tow, it is
really bad news. Heck it's bad news anywhere to have a rope break low.
It can be FATAL . lets get rid of those poly ropes. And in the long run
the Hi Quality ropes ARE cheaper, and when they are used up, you can use
them for other things, not just throw them away. How green is that?
Nick Kennedy
Grob Twin Astir TF
LS-6 XS
Blue Ridge Crash Karen Soaring 18 April 16th 11 03:16 AM
Scuttlebutt on the Blue Angel crash?? Charlie Wolf Naval Aviation 11 May 7th 07 11:45 PM
Blue Angels Crash MWB[_2_] Aviation Photos 15 April 25th 07 06:50 PM
Blue Angels Crash RAP Flashnet Aviation Photos 0 April 24th 07 04:55 PM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
