Trafficscope PIREP - long
Old November 21st 03, 08:27 PM
SeeAndAvoid
Default Trafficscope PIREP - long
Hey all,
Just got a new Surecheck Trafficscope VRX (the model with altitude
racking) - which I'll refer to as "the unit" - and since theres been some
discussion and interest in these types of devices I'll give you my opinions
on it. Aircraft Spruce had 1 in stock, so I got it and as soon as it
arrived I went out to the airport. The packaging is very nice, a hard case
with 'trafficscope' engraved on it, foam cutouts to hold everything,
cigarette lighter adapter and headset adaptor, and a well written color
manual. Of course I didnt even crack open the manual just to see how easy
it is to use and figure out without it. Luckily it also came with a
laminated quick reference card, I glossed over that for a second.
On the way to the airport I fired it up to see how it'd do, it picked up a
few airplanes alright, one I saw less than a mile away and it tracked it
pretty accurately from what I could tell.
For some reason I thought there was a built-in speaker, but there isn't, you
can only hear the warnings with a headset plugged in or running a cable to
your audio panel. I used a cable and connected to a jack just for this type
of unit into my audio panel (PS Engineering PMA7000B). Waiting to hear
something, of course there was no traffic around. I was wondering why the
few airplanes on the ground taxiing around wouldn't set it off, or the ones
on take-off or landing. This is a passive unit, it doesn't interrogate like
a TCAS, so since radar doesn't quite make it to ground level at my airport,
those airplanes transponders weren't firing off. As soon as they got about
500' AGL they sure did. Finally I got to hear the female voice warn me
about the traffic, and it was loud, had to turn the volume down.
Time to go flying. Couldn't figure out where to put it. I had two cables
going into it so that was my only limitation. I put it left of right in
front of me. On takeoff I found out that wasn't the best place. This was
in a C182, which has a high panel to begin with, right of center, just to
the right of the rear view mirror turned out to be a better location. It
was dusk, so right after takeoff I turned on the backlight. It's blueish
and pretty readable. Not long after takeoff the warnings began. First, one
in the pattern, then a jet with Mode S or TCAS above, along with a Wake
Turbulence verbal warning about that airplane. It'll track up to 3 targets
but only display the closest one. The two closest must have been somewhat
equal distant as the mileage and altitude display would shift from one to
the other, otherwise altitude changes like those were nearly impossible
(500' above - 300' below - 400' above). Mostly I got the "no threat"
message. I then called for flight following, the controller seemed in a
good mood, so I told him we were testing out some traffic alert equipment
and request traffic within 2-3 miles be called even if it may not be a
factor. He started calling a couple and the unit was dead on as far as
range and altitude. One he called and we saw we later got a traffic
advisory on. It was going from 9 to 6 o'clock, was near our altitude, and
mustve been faster as the actual mileage was decreasing - but was no factor.
The unit doesnt know azimuth, so it sees traffic getting closer in altitude
and range - so it warns you of it.
Then it was off to a fairly busy area near an outer marker thats usually
full of airplanes practicing an ILS. Sure enough there was traffic there, a
few of them. The controller told us of their altitudes, we climbed 500'
above that and saw them all and watched the unit go to work. It was busy
and giving verbal warnings. This was also a chance to check my new audio
panels marker beacon receiver, so between approach, unicom, the unit, and my
marker beacon, there was a lot coming through the headsets.
Then it was off to a less busy airport to buy some gas. Not much traffic,
just the occasional jet overhead on an arrival that would light up the Mode
S indication. Just after runup there wasn't much going on and we got ready
to taxi to the runway. Just then the unit shows some traffic nearby, next
we heard 5 clicks, runway lights come on and a position report over unicom
of inbound traffic. We head back home and the traffic picks up, it was a
clear night and we were able to see all the targets the unit told us of.
Not all of these were called by approach as they were not always merging or
a factor. Back in the pattern there were two aircraft, the unit picked them
up with ease.
Overall my copilot/flying buddy were pretty impressed by this unit. We
didn't find ourselves staring at it like we thought. One of the aircraft
that it warned us of we may never have found visually. It was 4-5 o'clock
low and overtaking, at our altitude. The controller called it and then we
saw it and climbed, but normally I don't think we'd have seen it. We heard
the controller call that airplane to call us as traffic, but he didnt see us
until way after we saw him and climbed up. There is a light that says XPNDR
Conflict, this stayed lit at all times. I'm not sure it was picking up my
transponder. The light also doubles as an over/under temp warning, but it
came on right away and never came off. The unit was barely warm to the
touch. I kept it at Maximum Detection, which is 1,500' and 5nm, and in
Flight mode. There is also Ground mode which only looks above 200', and an
Auto mode which starts at Ground and switches to Flight once you gain 500'
of altitude.
The unit isn't small, but the antenna isn't too tall so you can place it
about anywhere on top of the dash. The display is easily readable. It's
got a built in altimeter that reads pressure altitude, this seemed to be
accurate, and some of the warnings we got were dead on vertically (verified
with the controller) and it derives the readout by taking the Mode C of
traffic and subtracting the onboard altimeters altitude. I'm not so sure
about the Wake Turbulence advisories. The book says if Mode S aircraft are
within 2 miles and 1,000' above, you'll get an alert. We didn't get
verification from the controller on the altitudes, but they sure looked a
lot higher than 1,000' above, more like 5 or 6 thousand above. It is
possible that a smaller aircraft nearby had a Mode S transponder, or maybe
that high jet had a pretty powerful transponder and fooled the unit into
thinking it was closer than it was. The book says this is possible but not
likely.
That's all I can think of at this time, going to take it on a 10 hour trip
next week, this was just a 1.5 hour trip around the area. So far it seems
like a good deal for the money. I'm impressed by the level of detail
Surecheck has put into this unit, the packaging, and their frequently
updated website. I also called them a couple times before I bought with
lots of questions, always nice and helpful. They are just getting
production back up to speed, apparently a vendor who made a part for this
unit bellied up and they had to look elsewhere, or so I've heard. Good luck
finding one in the next few weeks, there are a couple around.
Chris
Old November 21st 03, 09:31 PM
Marco Leon
Very thorough an informative. I solicited some PIREPS on this a while back
so thanks for the PIREP. It sure looks like SureCheck got it right with
version #2 (I wonder if they're owned by Microsoft? ).
Marco
"SeeAndAvoid" wrote in message
ink.net...
Hey all,
[snip]
Chris
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old November 21st 03, 10:22 PM
Jay Honeck
Thanks for the PIREP.
Two questions:
1. Price?
2. Size?
Have you thought about yoke-mounting it?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 21st 03, 11:42 PM
SeeAndAvoid
Price: I got it for $995. It lists for $1195, A/C Spruce had it for over
$1,200. When I asked if they matched their competition (Pacific Coast
Avionics $995, but out of stock) they said they would, and did.
Size: from their website http://surecheck.net/five/avionics/ it says
Dimensions Length
Height
Width 5.36" (136.2 mm)
2.00" (50.8 mm)
3.65" (92.7 mm)
Length would be Depth, so yoke mounting would be tough.
There are instructions for panel mounting it, but I see a couple problems
with that. First you have to get an external antenna, either the one they
offer that you put on the inside of you window (kinda strange for a panel
mounted avionic) or a fin antenna on the bottom of the airplane. Next, you
can't change out the batteries easily if you had to. Next, if power is lost
and theres a plug for power plugged in, the unit will NOT operate, even if
you have fresh batteries in it. I see this as a flaw, panel mounted or not.
The manual reads "Battery power will be bypassed when a plug is inserted
into the power jack, even if no current is supplied." Perhaps in the future
they could maybe have some kind of indication that power has been lost and
is running on battery power. Like my Ipaq, or my Bluetooth GPS, or my old
Airmap300.
In the future I may mount it to the bottom of the overhang in the top of my
panel. It sticks out far enough to do this and the unit has a couple holes
on the sides to use thumbscrews and some kind of mounting bracket. I'd have
to use their external antenna though. So far though it'd block my top
flight instruments, or on the right my fuel gauges. For now it's up top.
Chris
"Jay Honeck" wrote in message
news:umvvb.265505$HS4.2369756@attbi_s01...
Two questions:
1. Price?
2. Size?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 22nd 03, 02:18 PM
Tom S.
Two questions:
1. Price?
2. Size?
http://surecheck.net/five/avionics/vrx/
Old November 24th 03, 08:17 PM
Snowbird
"SeeAndAvoid" wrote in message link.net...
Hey all,
on it.
Thanks for the Pirep, very interesting!
Sydney
Old November 24th 03, 09:24 PM
Viperdoc
Along the same lines, I recently traded my old King transponder for a new
Garmin GTX330. In addition to nice features like pressure altitude readout,
count up, count down, flight timers and aural altitude alert, its main
advantage is the mode S traffic readout.
Coupled with a Garmin 430 or 530 it provides the locations of multiple
(transponder equipped) aircraft within a twelve mile radius. The information
includes relative altitude, flight vector, and potential conflicts. There
was an excellent review in Aviation Consumer within the last few months
about the system.
After a little use, it's simply amazing how much traffic out there I never
saw, even with a careful scan. Even after a traffic alert it was difficult
to pick up other aircraft even within a half mile or less. Flying an
approach in a busy class C it was also neat seeing planes getting vectored
onto the final approach course and watching the spacing.
Considering the installed cost with the trade of the old King transponder
was less than $3,200 this is one of the best safety investments around. For
those of us fortunate to already have a Garmin 430/530 the extra cost of the
new transponder was a small price to pay for the added security.
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 04:02 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 08:51 PM
Surecheck TrafficScope Pirep? Marco Leon Owning 30 October 21st 03 03:44 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 11:05 PM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 03:14 AM
