Wanted - Water ballast adjustment Screw LS-3a
Old April 20th 11, 05:59 AM posted to rec.aviation.soaring
Default Wanted - Water ballast adjustment Screw LS-3a
In an effort to get "Big Ugly's" water ballast system working
correctly I was hoping one of you might have the dump adjustment screw
from the ballast rocker. I only need one and prefer not to spend 500
Euros on a service contract. This is for an LS-3a, but they are the
same on many LS's and I beleive a few other manufacturers. Anybody got
a junk glider sitting around?
Bryce
Pics for better description: https://picasaweb.google.com/bsammet...14571164365970
Old April 20th 11, 02:48 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Apr 19, 9:59*pm, "
Bryce
Pics for better description:https://picasaweb.google.com/bsammet...14571164365970
I'll take a look in the barn, may have it because we made one flyable
LS-3a from two disabled candidates about 20 years back. If not, you
can get your local TIG welder to make it up from a 6mm bolt and flat
washer for his minimum rate.
Cheers,
JJ
Old April 21st 11, 08:49 AM posted to rec.aviation.soaring
Bryce
washer for *his minimum rate.
Cheers,
JJ
Thanks for checking JJ.....I had the welder plugged in and ready to
go, but at the last minute thought that there had to be someone with
an original laying around! Let me know if you run across any other
worthwhile -3 parts......maybe I can make the effort in the barn a
little more worth your time.
Let me know, and thanks in advance,
Bryce
Winter Water Ballast Scott Alexander[_2_] Soaring 14 November 27th 09 03:11 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Water Ballast Upgrade P.Corbett Soaring 5 December 5th 05 02:32 PM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
