Pawnee question
Old May 2nd 11, 03:40 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default Pawnee question
The local towplane operation has a Pawnee that back in 1996 had an STC
from STC Inc. (SA01154AT) modification to the wing attach cluster.
Apparently it still requires a wings off inspection every two years.
The owner of the operation has heard that there may be an inexpensive
permanent fix that eliminates the biennial inspection. Perhaps a gusset
plate welded onto the cluster. Is anyone familiar with that procedure?
Old May 4th 11, 02:05 AM posted to rec.aviation.soaring
T[_2_]
permanent fix that eliminates the biennial inspection. *Perhaps a gusset
Our wing attach cluster STC repair came from Schweizer and requires
annual inspections, but only the wing removal and dye check ever 6
years. It's not that hard to remove Pawnee wings if you have a hanger
and an engine hoist.
You can research STCs on FAA.gov.
Old May 4th 11, 04:14 AM posted to rec.aviation.soaring
T[_2_]
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgSAIB.nsf/2d69931bd1dab16b862572250070589f/c1850358cba7bf4a8625721f0052ec5c/$FILE/ACE-96-10.pdf
There are only 3 STCs I could find that are approved for the Wing
Cluster AD.
SA00992AT, Kosola Assoc, Georgia
SA01073AT, Schweizer Aircraft (the one we have mentioned above)
SA01154AT, STC Inc, (the one you say you have)
And I would think that once one of the STCs is installed, it would be
very difficult to change to a different one because of all the welding
that is done on original installation.
Old February 2nd 19, 04:58 PM posted to rec.aviation.soaring
permanent fix that eliminates the biennial inspection. Â*Perhaps a gusset
Cluster AD.
Hi guys,
I am trying to find the STC SA01073AT details. According to our aircraft's documentation, we have it installed. Is there any special procedure to perform a dye penetrant check every 6 years (drawings, instructions)? I suppose it may be included in STC, but I cannot find anything on the internet...
Old February 4th 19, 12:15 PM posted to rec.aviation.soaring
Bob Youngblood
Apparently it still requires a wings off inspection every two years..
Cluster AD.
Hi guys,
I have lots of documentation on all three STC's that were available for the wing spar attachment. I also have a letter from the FAA stating that two of the three are considered termination for the AD. Those two are the STC Solutions, SA01154AT, and the Kosala, SA00992AT. You may also apply for an AMOC for the Schweizer STC and possibly eliminate the wing removal inspection.. I do have a ccopy of the FAA letter and would be glad to pass it along. Bob
Old March 14th 19, 10:14 PM posted to rec.aviation.soaring
Larry Ruggiero
Default Pawnee STC question
Hey Bob, I’m up against what sounds like the same situation with our towplane. Could you send me the same documentation you mentioned? Thanks....
Larry Ruggiero, Carolina Soaring Association, Spartanburg SC
Old March 15th 19, 03:05 AM posted to rec.aviation.soaring
Bob Youngblood
Most inspectors do not understand the termination of the AD that is approved with the completion of the STC. I will be sending you the information that includes letters from the FAA which states that the STC acts as an AMOC and therefore no further wing removal is necessary. Bob
Old March 15th 19, 12:53 PM posted to rec.aviation.soaring
Could you please create a link for this so others can benefit.
Thanks in advance.
UH
Old March 15th 19, 04:55 PM posted to rec.aviation.soaring
Larry Ruggiero
This is the pertinent SAIB from 1996:
Larry Ruggiero
Carolina Soaring Assoc, Spartanburg SC
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
Pawnee AD /SB 25/53/03 sugarbush Soaring 1 June 13th 09 12:41 AM
Looking for Pawnee [email protected] Soaring 1 July 13th 08 12:35 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
Pawnee Damien Dyer Soaring 2 November 2nd 04 05:35 PM
