Alternative to SeeYou or Strepla
Old May 12th 11, 08:24 PM posted to rec.aviation.soaring
KarlBoutin
Default Alternative to SeeYou or Strepla
Are there alternative to SeuYou or Strepla flight planning and
Analysis software?
I
Old May 13th 11, 04:19 AM posted to rec.aviation.soaring
Andy[_1_]
Analysis software?
I
What do you want it to do for you? I don't use either and buying one,
the other, or both would not make me fly faster.
I use Cambridge Aero Explorer Plus and Winscore. They give me all the
information about my flights that I need.
Andy (GY)
Old May 13th 11, 05:11 AM posted to rec.aviation.soaring
soaringpilot[_3_]
Analysis software?
I
Depends on what you want to do with it. You can try Flight Display at
http://www.soaringpilotsoftware.com It is free, which means that you
may have to do a bit more work yourself to get pretty images.
Cheers,
Henryk
Old May 13th 11, 12:55 PM posted to rec.aviation.soaring
KarlBoutin
Analysis software?
I
Depends on what you want to do with it. You can try Flight Display athttp://www.soaringpilotsoftware.comIt is free, which means that you
Cheers,
Henryk
Thanks for the hints floks. I will see if those free version do what I
want.
I like to review my flights to see what could be improved. Planning a
task
is also what I have in mind.
I will try the demo version of SeeYou to evaluate if it is worth 200$
Old May 13th 11, 04:19 PM posted to rec.aviation.soaring
sisu1a
I have SeeYou and love it, but here are 2 freebie IGC file viewers:
http://slim.xinqu.net/kml/ -fixed at 10x speed
http://www.ywtw.de/igcsimen.html -more comprehensive/interactive
viewer
-Paul
Old May 13th 11, 06:31 PM posted to rec.aviation.soaring
Paul Remde
Hi Karl,
I sell SeeYou and StrePla, so I'm probably biased. But it is true that I
started selling them because I like them a lot and find them very useful.
SeeYou does not cost $200. It is $155. It is not free, but the thousands
of glider pilots using it around the world seem to think it is worth the
money.
http://www.cumulus-soaring.com/seeyou.htm
You can learn to use it quickly with the training videos available he
http://www.cumulus-soaring.com/train...raining-SeeYou
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"KarlBoutin" wrote in message
On May 13, 12:11 am, soaringpilot wrote:
Analysis software?
I
Cheers,
Henryk
want.
task
Convert StrePla trace to IGC without StrePla? Jeremy Zawodny Soaring 5 January 11th 07 04:20 PM
IMPORTANT- Seeyou V's Strepla and airspace violations. [email protected] Soaring 62 September 19th 06 12:43 AM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
SeeYou VS StrePla :---) Matthieu Soaring 3 April 3rd 05 12:10 PM
SeeYou 2.51 vs. StrePla 2.4 Bill Daniels Soaring 2 February 1st 04 10:59 PM
