How do I remove white fog from canopy?
Old May 16th 11, 02:50 AM posted to rec.aviation.soaring
Blake Miller[_2_]
Default How do I remove white fog from canopy?
I just picked up a new - used Phoebus C and the canopy is not scratchd
but has a slight white fog that cannot be removed with traditional
cleaning, Does anyone know if a product is available that will remove
this white fog?
If anyone is wondering, this is the Phoebus C that was on W & W for
the last 3/4 of a year. I am very pleased with the glider and was in
even better condition than I thought it would be in. I plan on making
this Phoebus like new over the next few years and replacing the
canopy. But in the meantime I would like to remove the white fog for a
clearer view while soaring.
Blake S Miller
Old May 16th 11, 04:09 AM posted to rec.aviation.soaring
mike
this white fog?
Blake S Miller
Don't know about white fog Blake or the cause, but check out
Micromesh. If the canopy can be saved Micromesh can save it.
mike
Old May 16th 11, 12:09 PM posted to rec.aviation.soaring
T8
this white fog?
Blake S Miller
Meguiar's "PlastX" would be worth a try. It's widely sold (Walmart,
etc.) for clearing plastic headlight lens covers and it is
(relatively) quick, inexpensive. I've not tried this on a canopy, but
it works great on automotive plastic. If this works, it would be
about 1/10 the effort of MicroMesh.
-Evan Ludeman / T8
Old May 16th 11, 04:46 PM posted to rec.aviation.soaring
mike
this white fog?
Blake S Miller
Blake,
When it is time to replace your Phoebus canopy contact Thermotec.
They have a canopy mold for the Phoebus and made one for the "C"
that I owned several years ago. I would avoid a blown canopy.
http://www.thermotecusa.com/ThermoTe...d%20Making.htm
Old May 16th 11, 09:04 PM posted to rec.aviation.soaring
vaughn[_3_]
"Blake Miller" wrote in message
this white fog?
The problem is probably a microscopic pitting of the plastic. As others have
mentioned, the ultimate fix is Micromesh, time, elbow grease, and beer. (Use
the beer on yourself, not the canopy.) Various products are available,
primarily for headlight restoration, that use some clear substance to fill the
pits, which restores the clarity of the plastic. These products all work (to
some extent) and may be worth trying.
Vaughn
Old May 16th 11, 11:14 PM posted to rec.aviation.soaring
Dave Nadler
this white fog?
Blake S Miller
Careful with RAS advice !
If you are lucky that white haze is just some waxy
product turned to dust. Try a good canopy cleaner
(no, NOT lemon pledge or any other home-remedy).
Don't mess with MicroMesh unless you have a very
good reason and know what you're doing. Otherwise
you might destroy a perfectly good canopy.
For what its worth,
Best Regards, Dave
PS: Good luck with that pretty old bird !
Old May 16th 11, 11:47 PM posted to rec.aviation.soaring
T8
this white fog?
Blake S Miller
For what its worth,
Best Regards, Dave
What part of "cannot be removed by traditional cleaning" eluded you,
Dave :-)?
-T8
Old May 17th 11, 04:47 AM posted to rec.aviation.soaring
bildan
this white fog?
Blake S Miller
I've polished out some badly scratched canopys but it's not an hours
work - more like weeks or months of very patient work climbing a steep
learning curve. I consider it a winter project. The results can be
pretty nice though.
If you need it done in a hurry, see if a professional plastics shop
will take the project. These guys can work wonders with Plexiglass.
I've seen cracks and scratches from a loose canopy being blown across
a ramp made to totally disappear. They usually aren't too expensive
compared to the alternatives.
Bill Daniels
Old May 18th 11, 02:52 AM posted to rec.aviation.soaring
Blake Miller[_2_]
Thanks to all for such thoughtful responses.
Blake
Old June 3rd 11, 06:50 AM posted to rec.aviation.soaring
Chris Donovan
Blake
I was stuck once...without 501 or some of the other products...used
crest, didn't have a choice, bad hazing right in front driving me
nuts...took about 6 hours over two days for a section about 12 x 12
inch's...still looks great...not for the feighnt of heart. years later
tried the headlight stuff...all of em...not worth the time of day
based on the results a month later. Found out the headlight cleaners
spread various chemicals and acylics...crest just filled with "marble"
dust from some place in Vermont...would trust the crest approach
before I would use the headlight things again. Check out sportys or
the pilot shop for the complete list of products...know in advance the
three step products use crest... (as part of the process) lots of
water and clean rags, a steady supply of clean rags ...I can not
emphasise enough... clean rags. Be very, very, carefull with the
products that rely on the foam cups and pads, just don't work as well.
It is so easy to make things worse with micromesh esp the pro kit and
a hand drill or power tool...learned from experience. Sonata or
whatever ...just as easy to use clean rags and use the rag once...I
mean for one wipe... till all the surface stuff is gone. then start in
with some joy or something really really mild, till the second layer
of crud is gone...I guess my main point here is NO shortcuts and any
product that says fast in the literature...run away from. Good luck.
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 White Knight 2 on July 31 02.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 2 August 1st 09 07:56 PM
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 White Knight 2 on July 31 01.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 0 August 1st 09 01:43 AM
How to Remove Piston from Cylinder Paul Dow (Remove Caps in mail address) Owning 20 October 6th 08 10:01 PM
Remove references etc... Andy Davey Soaring 0 October 24th 04 10:49 PM
White over white is alright? Ron Natalie Piloting 3 July 16th 03 05:24 PM
