Glider Recommendations
Old May 18th 11, 12:23 AM posted to rec.aviation.soaring
Justrolln
Default Glider Recommendations
I’m new to the sport and am thinking about getting my first glider
this summer. I was hoping that you guys would all put your 2 cents in
and help me sort through all the wonderful why A is better than B…
Some things I’m concerned about are
I’m 6’2” and mostly torso. When I sit in a DG 1000 I take up a LOT of
the cockpit. It’s not uncomfortable, but I don’t think I would go any
smaller…
I’m paralyzed from about the waist down – so I will be using a hand
controlled rudder (even more reason to have a good sized cockpit) –
Also, pushing myself around all day in my wheelchair has made my
shoulders a bit wide… And, because I sit on my butt all day long, it
would be nice if I could fit a 1-2” pad under my butt while flying –
to prevent pressure sores on those long flights.
Ease of assembly: since I can’t do it myself – I’m sure to be asking
others for help – and I’m sure people won’t hate me as much if my
glider is not a pain to put together…
Motor: If I land out, it might be a really bad day for me. Sitting
in the glider waiting until crew arrives could be a big bummer… not a
total necessity, but a good thing to keep in mind.
Flaps: I think I’d rather not have them… I’m not sure how often you
adjust them in flight, but I’ll have right hand stick, left hand
stick, trim, spoilers, radio to worry about operating with my hands
already. I figure one less thing would be ok… But, if they really
help out maybe I should get them – I’m not too sure on this one
Type of flying: I made it out to avenal for a day last week and had a
blast, while I will do a fair amount of hanging around my local
airport (crystal) my main goal will be cross country and racing.
$: this is most likely the most important thing… I would like to
keep it around the $50,000 or so mark. I would pay more if there is
an engine in there (I’ve seen some DG 400s in the 60s…) and if I can
spend $30,000 and get 95% of a $50,000 ship, i'd rather do that
Any input would be great, or if you have questions that I haven’t
thought of that would be great too.
Ships I’ve considered
ASW 20
ASW 24 (how do these handle – fast thermaling speed?)
Genesis 2 (big cockpit – but how does it fly)
Discus (with large fuselage)
Ventus
DG 303 elan
LS-3
PIK 20E
DG 400
Ventus CM
Thanks again for any help -
Old May 20th 11, 01:11 AM posted to rec.aviation.soaring
jsbrake[_2_]
I'm the (newly assigned) chapter manager for one of the Freedom's
Wings Canada chapters (providing inspiration flights and flight
training for the physically challenged)... we're looking at $8,000 per
ship to modify our remaining Grob 103's to have hand controls. My
soaring club just got an ASK-21 with factory-installed hand controls,
that was a pretty penny on top of the cost, too.
Your posting raised some concerns for me:
- you say "new to the sport", but not how much experience you have,
nor the ships you've flown (other then DG-1000). Are you prepared to
handle any of the ships you mentioned?
- most of the ships you listed are flapped, which you wanted to rule
out
- motor gliders are more workload and extra training is required (and
maintenance)
Flaps aren't good or bad, they're "different". There are advantages
and disadvantages, and pilots far more experienced than I could extol
the virtues of having either. I fly both (my own ship is flapped),
and it's certainly simpler without. You'll want to follow the KISS
principle, I should think.
You might wish to contact Freedom's Wings Florida, based at Tampa Bay
Soaring Society for recommendations and information on modifying US
gliders.
Good luck in the search!
-John
Old May 20th 11, 03:00 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
The hand controls I have seen have been on ships that drive the rudder
with a push rod, like the G-103. The hand control is mounted on the
left side and is connected to the rudder push-rod, behind the rear
seat. How does one hook a hand control to a ship that uses cables to
drive its rudder? Most rudder pedals only move the rudder on one side
and use a spring to keep tension when the other pedal is moved.
JJ
Old May 20th 11, 11:21 PM posted to rec.aviation.soaring
glider12321
drive its rudder? *Most rudder pedals only move the rudder on one side
JJ
I have also seen a G102 set up with hand controls. The spoiler handle
was un sprung and had a detent so it could be set for landing and
rudder controlled with the left hand.
Old May 21st 11, 07:26 AM posted to rec.aviation.soaring
JJ
I am a volunteer instructor for Freedoms Wings International..we fly
out of several NE airports.
We have two Grob 103's with hand control rudder and spoiler with
detents...
Yes, the Grob has a "pushrod" rudder which allows a simple hand
control , connected to the rear left rudder pedal to control either
left or right rudder......hand control can be fitted to front or rear
seat as well......other gliders with cable controlled rudder will be
more difficult to fit a hand control rudder.
As far as I know, the Grob 103 and the ASK 21 are "factory approved"
for manual control.....
I am not usre if any single seat gliders come with factory approved
manual control..if not, considerable FAA paperwork may be required....
I would suggest that you consider the Gorb 103......a two seater has
some obvious advantages, and can alway be flown solo if desired...also
should fall well short of your price range....
even with manual control modifications...
You can do a web search for freedomw wings international and get some
contacts for further information
Bob Cook
Old May 21st 11, 08:43 AM posted to rec.aviation.soaring
Reed von Gal
On May 20, 11:26*pm, "
JJ
We have two Grob 103's with hand *control rudder and spoiler with
detents...
You can do a web search for freedomw wings international and get *some
Bob Cook
There is a Grob 103 at Mile High Gliding in Boulder with the hand
controls. It isn't currently set up but can be with no problem I hear.
They also have a 102 in a trailer with hand controls I believe.
Reed
Flapped Glider Recommendations... noel.wade Soaring 54 January 11th 08 12:58 AM
DME recommendations mindenpilot Owning 27 April 11th 05 06:23 PM
Recommendations - near FLL Hilton Piloting 2 March 16th 05 07:04 AM
MFD recommendations Richard Kaplan Owning 13 January 27th 04 05:04 PM
MFD recommendations Richard Kaplan Products 13 January 27th 04 05:04 PM
