On May 18, 11:45*am, JJ Sinclair wrote:
On May 18, 10:23*am, Andy wrote: On May 18, 9:44*am, Steve Koerner wrote: I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW I'd be interested to hear how that works out. *There is a least one spacer block inside the frame extrusion and it looks like it would have to be extracted, drilled, and replaced. *There may be two each side. *Given the limit access to the extrusion opening it could be a bit awkward to work the inner blocks. If I was going to larger bolts I think I'd relocate the handles and keep them on 5/16 socket cap bolts. *They wouldn't need the spacer blocks as long as a moderate torque was used. Andy (GY) The plot thickens, I moved both wings aft in order to get a good look at the forward corner of the fiberglass top. The top has an aluminum rail where it meets the lowar trailer and this "L" member overlaps the cross member (where the hinge plate is bolted). There are 4 large aluminum rivets on each side that bind these members together. Well, all 4 rivets on the right side were sheared off and 2 on the left side were sheared off! The forward 'shove' from the struts would try and shear off these rather weak fastners as they are loaded in "shear". The thing I don't understand is why the large steel bolts are shearing off, because they are not loaded in shear? I replaced the corner rivets with 1/8" steel rivets. JJ- Hide quoted text - - Show quoted text - JJ: I don't think that the big bolts are shearing off. They are breaking due to a gradual fatigue process in tension. What I'm thinking is that it is the fore and aft forces due to road bumps and/ or washboard acting against the inertia of the top that is putting the cycled load on the bolts that eventually is their unduing. The fatigue thing was definitely confirmed by Howard Banks based on the observations on Andy's broken bolt. When you said yesterday that you checked your bolts, did you really check them for incipient fatigue damage? Very interesting that there are sheared rivets going on as well. I'll have to look for that too. GW |
.. * When you said yesterday that you
checked your bolts, did you really check them for incipient fatigue damage? I didn't remove and inspect the bolts because I was afraid the struts would move the top, but thinking about it now, I don't think the top would move if it was fully open and struts extended all the way. I'll give it a try................If you hear a loud scream from no cal, it means the top moved on me! Dave wants pictures, but some of us don't know how to post pictures along with a whole bunch of other things having to do with computers! JJ |
On May 18, 2:22*pm, JJ Sinclair wrote:
. * When you said yesterday that you checked your bolts, did you really check them for incipient fatigue damage? I didn't remove and inspect the bolts because I was afraid the struts would move the top, but thinking about it now, I don't think the top would move if it was fully open and struts extended all the way. *I'll give it a try................If you hear a loud scream from no cal, it means the top moved on me! Dave wants pictures, but some of us don't know how to post pictures along with a whole bunch of other things having to do with computers! JJ The top will move with the struts fully extended and the bolts removed. Even with one hinge outboard bolt removed that corner of the top rises and it look 5 of us to align the parts to get the replacement bolt in. (people were available and clamps were not) Please clamp the parts together so they can't move and then only remove one bolt at a time. Andy |
![]() The top will move with the struts fully extended and the bolts removed. *Even with one hinge outboard bolt removed that corner of the top rises and it look 5 of us to align the parts to get the replacement bolt in. (people were available and clamps were not) Please clamp the parts together so they can't move and then only remove one bolt at a time. Andy Yep. the inboard bolts came right out and looked fine, but the outboard bolts didn't want to come and I wasn't inclined to force the issue. A gap between the hinge plate and cross-member did appear as I loosened the nut. I believe the outboard bolts fail after the bolt is loose and repeatedly banged around (up & down + for & aft). Once the outboard bolt gives way, the inboard isn't long for this world. I think we're OK if the bolts are tight and kept tight. Cheers, JJ |
On May 18, 12:30*pm, Steve Koerner wrote:
On May 18, 11:45*am, JJ Sinclair wrote: On May 18, 10:23*am, Andy wrote: On May 18, 9:44*am, Steve Koerner wrote: I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW I'd be interested to hear how that works out. *There is a least one spacer block inside the frame extrusion and it looks like it would have to be extracted, drilled, and replaced. *There may be two each side. *Given the limit access to the extrusion opening it could be a bit awkward to work the inner blocks. If I was going to larger bolts I think I'd relocate the handles and keep them on 5/16 socket cap bolts. *They wouldn't need the spacer blocks as long as a moderate torque was used. Andy (GY) The plot thickens, I moved both wings aft in order to get a good look at the forward corner of the fiberglass top. The top has an aluminum rail where it meets the lowar trailer and this "L" member overlaps the cross member (where the hinge plate is bolted). There are 4 large aluminum rivets on each side that bind these members together. Well, all 4 rivets on the right side were sheared off and 2 on the left side were sheared off! The forward 'shove' from the struts would try and shear off these rather weak fastners as they are loaded in "shear". The thing I don't understand is why the large steel bolts are shearing off, because they are not loaded in shear? I replaced the corner rivets with 1/8" steel rivets. JJ- Hide quoted text - - Show quoted text - JJ: I don't think that the big bolts are shearing off. *They are breaking due to a gradual fatigue process in tension. * What I'm thinking is that it is the fore and aft forces due to road bumps and/ or washboard acting against the inertia of the top that is putting the cycled load on the bolts that eventually is their unduing. * The fatigue thing was definitely confirmed by Howard Banks based on the observations on Andy's broken bolt. * When you said yesterday that you checked your bolts, did you really check them for incipient fatigue damage? Very interesting that there are sheared rivets going on as well. *I'll have to look for that too. GW- Hide quoted text - - Show quoted text - I think there is significant shear loads on the bolts. The top of the trailer mates to the lower half with a rubber seal. The top has considerable mass and inertia. Any time the trailer floor moves up and down, as on a washboard road, the vertical acceleration is transferred to the top by the gap seals which will yield and then by the forward hinges. There will therefore be a cycling shear load on the hinge plate bolts any time the trailer moves over a rough surface. Given that the plain shank of the bolt is not long enough to engage in the rear wall of the front frame extrusion, or the spacer plate, or the hinge plate, it's really not surprising the bolts fail. Another factor is the the bolts compress the thickness of the 2 layer grass top. Over time the top yields reducing the bolt clamping force and allowing relative vertical motion between the parts that were intended to be clamped together, but now are not. I found deep compression of the glass outer shell under the handle ends where the bolts failed. This could have be avoided by using a solid spacer inserted into the shell. Andy (GY) |
Andy:
I certainly agree that once the bolts become loose they will be seeing shear load. I also agree that compressing the fiberglass shell over time is a certain way for them to get loose. That sounds like a pretty good theory. Of course, once they get loose, they'll be under increased tension cycling too. As JJ has said, the key thing may be to not let them get loose. I can recall that my left rear latch had become a bit troublesome prior to the failure. I now realize that meant that the bolt was probably loosening in the left front. My latest observation is that the hinge plate bolts on my trailer are marked 8 8 which is not a high strength bolt. So I'm now thinking that my corrective action will be to upgrade to high strength and periodically monitor those bolts to keep them tight. GW |
![]() I can recall that my left rear latch had become a bit troublesome prior to the failure. *I now realize that meant that the bolt was probably loosening in the left front. Yep, nothing new here, my ash-25 trailer was doing the same thing, it just didn't get to the bolts before I sold it to John in Australia (John, check your bolts). I do remember the latches had moved forward as my present latches have, Andy is right, the forward pressuer from the compressed struts will shear the aluminum rivets then apply pressure under the hinge bolts which will degrade the fiberglass or gall the aluminum top which will lead to LOOSE BOLTS over time. Loose bolts = sheared bolts! My trailer closes and latches better, now that I have replaced the sheared off aluminum corner rivets with 1/8" steel rivets. BTW, I can see a slight forward bend in the right side of my fiberglass top just outboard of the hinge plate. Cheers, JJ |
On 5/19/2011 7:04 AM, JJ Sinclair wrote:
My trailer closes and latches better, now that I have replaced the sheared off aluminum corner rivets with 1/8" steel rivets. BTW, I can see a slight forward bend in the right side of my fiberglass top just outboard of the hinge plate. My metal top Cobra trailer has had a forward bend on both sides for at least 6 years, probably longer. I also just noticed the pivot holes for the top are elongated fore and aft. I may add a bushing to them, which would move the top back 1/8" or more, and make it easier to close. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
I suspect this problem has nothing to do with loads imposed by the gas
springs or bumpy roads or inertia. I think the tension in these bolts that leads to failure results from “bridging” the trailer across dips in the road. Our trailers can be viewed as two beams, the floor section and the lid, setting one on top of the other. These beams are pinned together at each end; at the front by the hinge pins and at the rear by the latch pins. During normal use the lower beam, the floor section, is loaded along its length by the sailplane parts and supported in the center by the axel. The trailer sags at each end. The resulting bending loads put the top edge of the lower section in tension. These bending loads also pull down on the front and rear of the lid. Meanwhile, contact with the lower section along the claim shell joint pushes up on the center of the lid. As a result the lid also sees bending loads in the same direction as the floor section. This puts the lower edge of the lid is in compression, not tension. As a result the front bottom edge of the lid is pulled toward the rear, away from the mating surface of the lower section. Loads in this direction would be transferred to the hinge brackets and not to the bolts which clamp the brackets to the lid. Furthermore, the deflections would probably be small relative to the play in the pins. On the other hand, when you tow the trailer across a dip, such as starting up a steep driveway, the trailer may form a bridge across the dip, with the back end dragging on the pavement and the front end supported by the tow vehicle’s hitch. This causes the trailer to sag in the middle, opposite to the normal loading. This puts the upper surface of the lower section in compression. The lid is still pinned in place at the front and the back, but it doesn’t carry much load so it does not bend nearly as much. This would be especially true with the fiberglass tops which are probably much stiffer than the aluminum version. The lid effectively takes a short-cut across the gap as the lower section sags away in middle. As a result the front bottom edge of the lid is pushed forward, past the mating surface of the lower section. Loads in this direction would be transferred through the bolts, putting them in tension. Some years back a number of us, led by JJ, myself included, found substantial cracks on our trailer tongues, opening from the bottom. Same story: Bridging. The odd thing about the current problem is the sudden onset of multiple events… unless you all drove across the same ditch??? Mike Koerner |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra top hinge plate bolt failure | Andy[_1_] | Soaring | 43 | May 24th 11 03:41 AM |
Cobra top hinge plate bolt failure | JJ Sinclair[_2_] | Soaring | 0 | May 18th 11 07:45 PM |
Cobra top hinge plate bolt failure | Andy[_1_] | Soaring | 0 | May 17th 11 12:01 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
