flyWithCE tip #4: TEST: How can I feed my electronic gadgets?
Old May 20th 11, 09:51 PM posted to rec.aviation.soaring
urosp
Default flyWithCE tip #4: TEST: How can I feed my electronic gadgets?
Batteries are (most of the time) the weakest link in our small
gadgets. Because of that the first question is usually how long will
our device run on fully charged batteries and how quickly can I
recharge or replaced empty batteries. This was the reason why I have
decided to check what are the power supply options for flyWithCE
Flight recorder. Since flight recorder can be powered by standard AAA
batteries or by external USB power supply this article is interesting
also for users that have similar devices.
Read tip #4: http://www.flywithce.com/tip_04.html
Best regards
Uros Podlogar
Old May 22nd 11, 10:57 PM posted to rec.aviation.soaring
smithcorp
Read tip #4:http://www.flywithce.com/tip_04.html
Neat Uros, thanks. I have had a few frustrations with using
rechargeable AAAs in my flywithCE logger, so the info on rechargeables
is useful.
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 05:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 06:39 AM
Spouses and new gadgets john smith Piloting 7 August 15th 06 10:59 AM
PLEASE DON'T FEED THE TROLL Darkwing Piloting 2 March 16th 06 03:46 AM
Military pilots complain gadgets added to helmets causing neck Otis Willie Military Aviation 0 September 9th 04 03:47 AM
