digital ballasts
Old May 27th 11, 12:50 PM posted to rec.aviation.soaring
julia joy
Default digital ballasts
Another great feature of digital ballasts is the ability to run both
MH and HPS bulbs on the same ballast without having to flip a switch
(it should be noted that not all digital ballasts on the market are
programmed (or optimized) to do this properly, Eclipse LED digital
ballasts are). Research shows that Eclipse LED ballasts are optimized
for the most efficient HID output available. Our digital ballasts are
designed to give you maximum light output at the best efficiency
possible. Compare the Eclipse LED digital ballasts with similar
wattage magnetic ballasts
http://www.eclipseledcompany.com/Digital_Ballasts.html
Old May 28th 11, 03:14 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Ooh! Digital ballast! Don't need rubber wing bags any more, just select
the ballast item on your flight computer and crank in as much digital
ballast as you need.
email me)
Old May 28th 11, 04:13 AM posted to rec.aviation.soaring
Bart[_4_]
Downloading additional ballast during a contest should be banned!
B.
Recommend a digital a/h Martin Woodcock Soaring 4 September 8th 09 10:48 PM
Digital meters 3 [email protected] Home Built 10 April 25th 06 06:30 AM
Digital OAT Jim Burns Owning 39 August 3rd 05 05:24 PM
$3 digital voltmeters Jim Weir Home Built 8 January 10th 04 04:51 PM
