Alternator Light on Bonanza
Old January 4th 04, 02:02 PM
Peter Shurman
Default Alternator Light on Bonanza
Occasionally, notably when the battery is in a minorly discharged state (but
not always), I'll get an alternator offline indicator light and see the
ammeter go negative. This will either disappear immediately on its own or
require an alternator switch off/on reset by the book. It's been
intermittent for a year and the mechanics can't isolate it. Any ideas
appreciated.
Peter Shurman
Bonanza F33-A C/GRDT
Old January 4th 04, 02:36 PM
Dan Luke
state (but not always), I'll get an alternator offline indicator
light
and see the ammeter go negative. This will either disappear
immediately on its own or require an alternator switch off/on
reset by the book. It's been intermittent for a year and the
mechanics can't isolate it. Any ideas appreciated.
Sounds like a high resistance connection somewhere. First things to
check are the alternator and master switches, then make sure all the
ground connections are clean and tight.
Dan
C172RG at BFM
(remove pants to reply by email)
Old January 4th 04, 04:29 PM
Stu Gotts
Look to see the last time the alternator was o/h'd or at least the
coupler was serviced. Then check the SB's. It might be a 500 hour
item. And yes, check the switches.
On Sun, 04 Jan 2004 14:02:21 GMT, "Peter Shurman"
appreciated.
Peter Shurman
Old January 5th 04, 01:33 AM
markjen
My 77 F33A had similar symptoms for awhile, then went AWOL all-together.
Bad regulator. The old one was original and was quite a boat anchor - new
one much smaller/lighter.
ABS recommends you overhaul the alternator every 300-hours. There is a
failure scenario where the bearings fail and send metal into the engine. So
if you're beyond this, you might want to overhaul it to start with.
- Mark
A36 Bonanza turbo prop Jeff Owning 46 January 7th 04 02:37 PM
WTB: Nose Gear Assembly for Early Model Bonanza Eric Ulmer Aviation Marketplace 4 November 16th 03 10:50 PM
Bonanza Alternator Light Peter Shurman Owning 0 July 27th 03 07:42 PM
Early Bonanza or Apache? Brinks Owning 11 July 16th 03 06:01 PM
WTB: Bonanza Mic M. E. Mermigas, DDS Aviation Marketplace 0 July 11th 03 10:58 AM
