Anyone used FlywithCE?
Old June 6th 11, 05:00 PM posted to rec.aviation.soaring
Bob
Default Anyone used FlywithCE?
On Jun 5, 9:54*am, Rob Shepherd wrote:
Evening all,
Has anyone used one of the FlywithCE devices, comments on ease of use,
accuracy, battery duration would be much appreciated.
Cheers
Rob
Mine works fine. Just have to make sure batteries are charged. I
always do so now. Had a problem with downloading flights going too
far back, but the guys from CE worked with me on live computer
interaction and was fixed. GPS altitude shows higher than pressure
altitude when near class A level, which is typical for GPS. My Garmin
Pilot 3 shows the same descrepancy. The little gizmo works for
SeeYou and OLC, which is all I was wanting. Its a good bang for the
cheap buck. Sure will be good when they get the clearance for badge
use... maybe by early next year, if IGC gets things further clarified.
Bob
Anyone used FlywithCE? smithcorp Soaring 42 June 7th 11 12:24 AM
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 05:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 06:39 AM
FlywithCE PC[_2_] Soaring 1 January 10th 08 03:34 AM
FlyWithCE V2.1 SUA Ken Kochanski (KK) Soaring 1 June 14th 06 08:34 PM
