GPS-NAV problem on OLC
Old June 13th 11, 02:38 AM
Marianne G. Marianne G. is offline
Junior Member
First recorded activity by AviationBanter: Jun 2011
Default GPS-NAV problem on OLC
I uploaded a flight on OLC using GPS-NAV model20 output CAI file - I used the recommended software to convert the *.CAI file to an OLC file - the file passed all security checks but OLC still set the file status as invalid.
Does anyone have ideas on what the problem might be?
M. Guerin
Old June 13th 11, 05:27 AM posted to rec.aviation.soaring
Ian Reekie
I had exactly the same problem two days ago, I checked the file and
everything was ok with security. I deleted and repeated the upload a few
times and it worked (validated) on about the third attempt.
I think there may be a bug with their validation software for older
Cambridge CAI converted files. I will send an email to the OLC support, I
would suggest you do the same.
Old June 13th 11, 02:54 PM posted to rec.aviation.soaring
Tony[_5_]
everything was ok with security. *I deleted and repeated the upload a few
times and it worked (validated) on about *the third attempt.
Cambridge CAI converted files. *I will send an email to the OLC support, I
if i remember right the issues is a sort of "Year 2000" bug except
this time it is a "Year 2010". I had the same issue when I was using
a Cambridge 20 last year. I think you really just need to change the
file name by one digit or something, can't remember the specifics
though.
Is there a problem with rah? Scott Home Built 48 February 8th 07 01:45 PM
Help! GPS USB problem Richard Russell Piloting 4 August 16th 04 04:08 PM
Problem with this NG? Regnirps Military Aviation 10 April 29th 04 03:39 PM
Need Help with LS3 problem TJ Soaring 1 January 17th 04 05:13 AM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 04:25 PM
