Reprofiling LS6 wings
Old June 19th 11, 11:28 PM posted to rec.aviation.soaring
Ben C
Default Reprofiling LS6 wings
Hi all,
Given that down the track I will need to refinish my wings, I am
curious about
the process. I understand that LS/DG will not provide profile
information to
allow accurate reprofiling of the wings. Is it standard practice to
just
reinstate the profile that the wing had prior to refinish? Has anyone
taken a
profile from another aircraft to use, for example using a later LS6-c
to
reprofile an LS6-b? What about using an LS8 profile on an LS6, since
they are
supposed to be the same forward section?
Thanks, Ben
Old June 20th 11, 02:04 AM posted to rec.aviation.soaring
Bob Kuykendall
On Jun 19, 3:28*pm, Ben C wrote:
Is it standard practice to just reinstate the profile that
That's pretty much what you do. Make sure the wing profile is round in
front, pointy in back, and the waviness is below .004", and it will
probably be fine.
...Has anyone taken a profile from another aircraft to use, for
example using a later LS6-c to reprofile an LS6-b?
They're the same profile. Or at least the LS6-c left is the same as
the LS6-b left, and likewise for the corresponding right wings. I've
done template checks on several LS6 and a couple of LS8 to validate
it.
What about using an LS8 profile on an LS6, since they are
As you note, they're also pretty much the same, within the
qualifications noted above.
My advice: Don't bother trying to do a full profile job. The LS6 and
LS8 go like stink, generally fly very straight, and handle very well.
There is just about nothing a full profile job will do to change that.
It will defnitely add a bunch of weight and expend hundreds of hours
and thousands of dollars.
About the only things that would make much of a difference are the
leading edge profile back to about 15% chord, and getting the waviness
down to under .004". And my bet is that both of those are probably
already in pretty good shape.
Thanks, Bob K.
http://www.hpaircraft.com/hp-24
Old June 20th 11, 11:52 AM posted to rec.aviation.soaring
KN
probably be fine.
it.
Thanks, Bob K.http://www.hpaircraft.com/hp-24
Hi Bob,
I am a newbie in the sport and wondering how much wing surface
deformity would one
expect to see in this era glass ships. The deformity is caused by
shrinking/ settling of fiberglass
through time or there is a different mechanism? The more recent ships
with carbon fiber wings suffer
just a much? BTW, I enjoy following your work. Thanks
Khanh
Old June 20th 11, 03:27 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Hi all,
curious about
information to
just
taken a
to
they are
Thanks, Ben
Only the first 4" are critical and I would make 'quickie' templates
before stripping the wing. Set wing leading edge up on saw-horses and
mark span locations every 18" then make rough cardboard templates
starting at the root. Place wax-paper over L/E and goop up your rough
template with Bondo and lower them onto each indicated location. After
the Bondo dries remove and sand the edges to leave only the center
1/4" template. Be sure to mark each template 1 through 16, or so.
Then start the fun part, with a Porter-Cable, variable speed electric
orbital sander using 60 grit, 6" sticky back
disks..................remove all the gelcoat down to, but not
including the fiberglass structure. Check back after the 2 weeks this
may take and I'll give you the next step in you all Winter project.
Cheers,
JJ
Old June 21st 11, 03:11 PM posted to rec.aviation.soaring
jsbrake[_2_]
Before I make myself out to be too much of an idiot with a mostly-
likely-obvious question... is there a quick quide on the process of re-
profiling? My search in Google just now was fruitless, so I'm doing
something wrong. I'm not planning on doing it, but I'm curious about
the process.
Thanks!
- John
Old June 21st 11, 04:34 PM posted to rec.aviation.soaring
Luke[_4_]
the process.
Thanks!
- John
Hi John,
this is probably the best article to give you an idea of the work involved.
http://www.archive.jimphoenix.com/ar...UP%20wing.html
Luke Szczepaniak
Old June 21st 11, 04:37 PM posted to rec.aviation.soaring
profiling? *My search in Google just now was fruitless, so I'm doing
something wrong. *I'm not planning on doing it, but I'm curious about
the process.
Thanks!
- John
Yep.
Reprofiling only.
Identify and fill low areas- usually due to shrink over time.
Identify and remove high areas- rare, but it does happen.
Where are they? Ah that is the question.
Throw in refinishing and that is a whole different question.
The first time you do this you will do well not to make the glider
worse. Many do.
Few do it the second time.
UH
Old June 21st 11, 05:09 PM posted to rec.aviation.soaring
mattm[_2_]
the process.
Thanks!
- John
Yep.
Reprofiling only.
worse. Many do.
UH
That's the thing -- not to make it worse. Is it worth it to try
though?
My plane seems to fly about 10-12% worse than the Johnson
measured polar. The gelcoat is in pretty good shape overall
after 33 years though; it looks like a reprofiling is basically
a refinish project, which I'm not planning on doing anytime soon.
-- Matt
Old June 21st 11, 07:54 PM posted to rec.aviation.soaring
jsbrake[_2_]
Okay, I think need to be an idiot and ask the questions (I beg your
indulgence)...
I understand the part about getting the correct profile templates and
shaping the wing to the correct profile. However, doesn't that mean
that the wing will be thicker than profile once the gelcoat is sprayed
on? Or are the templates made deliberately thinner to account for
this added thickness? But then how would one know how thick to lay on
the gelcoat?
It seems to me that "re-finish" and "re-profile" are being used nearly
interchangeably, i.e. in both cases, the gelcoat is completely
removed.
Can it be that the gelcoat can be only partially sanded off, filled in
somehow (more gel?) to meet profile, then bond in another layer of
gelcoat? I've seen a wing repaired: new foam core, glass layers,
bondo then gelcoat, so I know small patches can be done this way (I
didn't get to see the gelcoat being applied).
Thanks!
-John
(and if these are _really_ stupid questions, just call me Hugo)
(no offense intended to anyone named Hugo)
Old June 21st 11, 09:01 PM posted to rec.aviation.soaring
Grider Pirate
indulgence)...
shaping the wing to the correct profile. *However, doesn't that mean
on? *Or are the templates made deliberately thinner to account for
this added thickness? *But then how would one know how thick to lay on
the gelcoat?
removed.
gelcoat? *I've seen a wing repaired: new foam core, glass layers,
Thanks!
-John
The best step-by-step I've ever found was on Jimphoenix.com. He
stripped, reprofiled, and refinished a set of Nimbus wings.
Unfortunately, I don't think it's still available, as he has moved to
Washington and is now more into boats. It might not hurt to email him
to see if he could send you the 'article'.
Cheers
PC-9 with all the wings :-) Glenn[_2_] Aviation Photos 1 August 19th 07 01:52 AM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
wings mark Owning 18 February 7th 04 10:07 AM
FS: SGS 1-35 Wings Michael Soaring 3 December 14th 03 06:51 PM
FS SGS 1-35 Wings MHende6388 Soaring 0 September 11th 03 02:06 AM
