Tiny vacuum pump
Old January 16th 04, 05:41 PM
Jim Weir
Default Tiny vacuum pump
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
http://www.rst-engr.com
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 06:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 09:08 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 05:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 06:42 AM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 05:22 PM
