Oudie vs Streak sunlight readability
Old July 4th 11, 09:01 PM posted to rec.aviation.soaring
Max Kellermann
Default Oudie vs Streak sunlight readability
Had the chance to make a photo of Oudie and Dell Streak 5" in direct
sunlight:
http://max.kellermann.name/download/..._vs_streak.jpg
Old July 4th 11, 09:56 PM posted to rec.aviation.soaring
T[_2_]
sunlight:
*http://max.kellermann.name/download/...oudie_vs_strea....
Thanks I've been looking at the Oudie too, have not purchased yet.
Interesting from a side view, what about head on direct? It looked
like a plastic overlay on the Oudie, or standard view from the side of
old tv LCD screens.
The Dell is shiny glass, I have problems with that (reflections) and
direct sunlight on the iPad.
How do they both fare with sunglasses or polarized lenses?
T
Old July 4th 11, 11:37 PM posted to rec.aviation.soaring
Max Kellermann
Not if your eye focuses on the display rather than the reflection
(which the human eye does extremely well, unlike a digital camera). I
tried an anti-glare foil once, but decided it's better without.
I don't have polarized sunglasses, but my cheap ones do very well with
the Streak. Cannot see a thing on the Oudie, with or without glasses.
Old July 5th 11, 03:51 AM posted to rec.aviation.soaring
Mike[_37_]
sunlight:
old tv LCD screens.
T
T,
Can not compare the Streak to the Oudie, but...
I have a Streak and it is quite good with polarized lenses when used
in portrait mode. In landscape mode the screen is not very visable.
The reflection issue with the Gorilla Glass on the Streak is really
not much of a problem or issue, as the Streak is fairly bright. A
slight angle change removes any reflection problem.
Another nice feature of the Streak is that it can be used for 5-6
hours without an external battery. Using XCSoar on the Streak is a
very good 'Tactical Soaring' program/device solution. And, if you
connect a Nano via Bluetooth, you have an excellent combination for
badges, contests and records, for a very reasonable price.
Good luck,
Old July 5th 11, 05:50 PM posted to rec.aviation.soaring
Fred Blair[_3_]
sunlight:
old tv LCD screens.
T
T,
not much of a problem or issue, as the Streak is fairly bright. *A
Good luck,
How do you get a secure igc out of the XcSoar?
Old July 5th 11, 05:56 PM posted to rec.aviation.soaring
Tony[_5_]
probably the same way you do out of the Oudie, i.e. you don't.
I haven't had an issue with sunlight readability on my Oudie this
season on several flights. I have non-polarized Ray Ban sunglasses
and fairly young eyes as far as glider pilots go.
Old July 5th 11, 06:00 PM posted to rec.aviation.soaring
Mike[_37_]
sunlight:
old tv LCD screens.
T
T,
Good luck,
How do you get a secure igc out of the XcSoar?- Hide quoted text -
- Show quoted text -
For badge flights I get a secure log from the Nano. If nothing has
changed recently, XCSoar is on the OLC approved software list.
Old July 6th 11, 03:02 AM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
I ordered one of these:
http://www.amazon.com/GlareStomper-3...13450&sr =8-2
to put on my Oudie and test the next time I fly. Don't know if it will work or not, but it was relatively cheap (at least compared to most stuff construed as "aviation-related"!), easy to install, and will be easy to take off if it doesn't.
AND...it will work on the Garmin I have in the car if all else fails.
If the link doesn't work, just search for "Glare Stomper" on Amazon.
Rob S.
ZAP
Old July 4th 11, 10:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
sunlight:
The viewing angle and reflections on the two units are so different, it
seems to be a poor comparison.
I suggest you ensure they are right beside one another, with the screen
surfaces in the same viewing plane, then get the camera at least 3 feet
back, ensure they are reflecting the same background (and not your
reflection on just one of them), zoom in with the lens, and then click away.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old July 4th 11, 11:34 PM posted to rec.aviation.soaring
Max Kellermann
Huh? They already are right beside one another, and they are in the
very same viewing angle. The reflected objects are similar enough
(the owner's head, and my hand, both illuminated by the sun; bright
sky on both). The HTC Magic that took the photo cannot zoom, sorry,
but that's about the only detail that doesn't match your description.
LCD Display Readability john smith[_2_] Piloting 4 May 29th 07 05:39 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Instrument Flight Rules 7 March 24th 05 11:00 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Piloting 17 March 24th 05 11:00 PM
Poor readability Kees Mies Owning 2 August 14th 04 05:22 AM
Streak Shadow david H Home Built 0 December 26th 03 11:22 PM
