Airstart reliability
Old July 8th 11, 05:08 PM posted to rec.aviation.soaring
Tom Nau
Default Airstart reliability
A friend of mine recently was involved in an outlanding accident. It
seems as though having an engine on-board would help to avoid
outlandings and therefore outlanding accidents. If there are any
generalities to be made, which are generally more reliable for
airstarts - sustainer systems or self-launch systems? My question
refers to gasoline systems and not electrics. And yes I understand
that no system is completely reliable and one should always have a
safe-landing site available even with an on-board engine. Thanks.
Tom
Old July 10th 11, 12:31 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
It does help avoid them; it doesn't eliminate them. Personally, I've
used my engine to avoid over 150 landouts in 16 years, with only one
landing, and that was on an airstrip.
If there are any
I'm not aware of any statistics showing a reliability advantage of one
over the other for in-flight restarts to avoid landing. My observation
is it depends more on the pilot than the type: if the pilot keeps the
system well-maintained, practices with it regularly, keeps a safe field
in easy reach, and begins the restart high enough to avoid pilot stress,
either system will start reliably.
If your concern is primarily avoiding a landout, then a sustainer system
is probably the best choice. This assumes you can get sustainer with
adequate climb rate at the density altitudes of interest, which might
not be possible for high desert areas.
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old July 11th 11, 07:18 PM posted to rec.aviation.soaring
Tom Nau
A friend of mine recently was involved in an outlanding accident. *It
*If there are any
airstarts - sustainer systems or self-launch systems? *My question
refers to gasoline systems and not electrics. *And yes I understand
safe-landing site available even with an on-board engine. *Thanks.
email me)
Thank you to all who responded.
Tom
Reliability and Clubs... [email protected] Piloting 23 August 27th 06 04:27 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Reliability of O-300 Captain Wubba Owning 13 March 9th 04 12:17 AM
Jabiru V Rotax reliability? Joe Home Built 11 September 5th 03 11:09 AM
Space Junk & GPS Reliability Doug Carter Instrument Flight Rules 9 July 11th 03 01:38 PM
