Seeking Marske Monarch or plans for same
Old July 18th 11, 05:22 AM posted to rec.aviation.soaring
Frank Whiteley
Default Seeking Marske Monarch or plans for same
I am looking for the plans for or a complete Monarch of the Marske
Flying Wings. Can anyone help me find one? E-mail me at
Thanks.
Thomas Johnson
Old July 18th 11, 05:50 AM posted to rec.aviation.soaring
Bob Kuykendall
Thanks.
Thomas Johnson
I suggest you get directly in touch with Jim Marske:
http://marskeaircraft.com/index.html
Thanks, Bob K.
Old July 19th 11, 12:29 AM posted to rec.aviation.soaring
JohnElliott
You might be interested in the Monarch sold by Kollman Wings at the
websited below. I am not sure if it is a Marske approved design or
not but it looks similar.
http://www.kollmanwings.com/Home_Page.php
The Monarch is an open cockpit sailplane that tows with hang glider
equipment. It is well matched for scooter towing or air towing behind
trike or Dragonfly. It thermals well at speeeds hang glider pilots are
used to and has similar turn radius in thermals. The control system
uses standard stick and rudder 3-axis control.
The Monarch H is a redesign of the Monarch fuselage to allow for prop
clearance. This allows for a motor to be mounted behind the pilot
similar to a trike.
Monarch H specs
wingspan.........................43.5'
wing area........................165 ft sq
Best L/D ........................20 @ 35 mph
Minumun sink....................135 ft/min
Empty weight...................180 lb glider version...... 250 lb
motorized
pilot weight......................130 lb to 250 lb
Stall speed...................... 30 mph @ max weight
Vne.................................65 mph.
Monarch H kit............................................... ......
$9,500
Monarch H ready to fly.....................................$14,500
Old July 19th 11, 02:40 PM posted to rec.aviation.soaring
Frank Whiteley
websited below. *I am not sure if it is a Marske approved design or
similar to a trike.
Monarch H *specs
* wingspan.........................43.5'
* wing area........................165 ft sq
* Best L/D *........................20 @ 35 mph
* Minumun sink....................135 ft/min
* Empty weight...................180 lb glider version...... 250 lb
motorized
* pilot weight......................130 lb to 250 lb
* Stall speed...................... 30 mph *@ max weight
* Vne.................................65 mph.
$9,500
Although I was doing this for someone else, I had chats with Matt
Kollman and Thomas Johnson last evening. It wasn't Jim that wasn't
responding, but apparently Matt Redsell after a first contact. The
new Monarch will be the H, with an improved fuselage.
Frank Whiteley
Old July 21st 11, 02:06 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
.. *The
I hope they improved the release system! A friend did several auto
tows. The info said it could be aero towed, so they hooked it up to a
Cub On tow it started to oscilate wildly in pitch (too fast?). He
tried to release, but couldn't and it PIO'd into the runway. My friend
received a severe head injury. If you fly a Monarch, for god's sake
wear a helmet!
JJ
Old July 21st 11, 05:18 PM posted to rec.aviation.soaring
Bill D
On Jul 21, 7:06*am, JJ Sinclair wrote:
. *The
Cub On tow it started to oscilate wildly in pitch *(too fast?). He
wear a helmet!
JJ
I don't know what happened to your friend (my condolences), but your
comment may be unfair. The Marske flying wings respond very rapidly
to pitch inputs but they don't oscillate.
Bill D
Old July 22nd 11, 07:58 PM posted to rec.aviation.soaring
Roberto Waltman[_2_]
In http://www.kollmanwings.com/Prices.html it says:
"For Monarch f and Pioneer 2 plans contact Jim Marske
http://www.marskeaircraft.com/ "
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale reader Home Built 1 January 26th 11 01:40 AM
Manchester England (EGCC) 4 - Monarch Andrew B Aviation Photos 0 October 12th 07 05:07 PM
Manchester England (EGCC) 4 - Monarch Andrew B Aviation Photos 0 October 12th 07 05:06 PM
$50 Monarch replacement caps on eBay Jose Flores Products 1 February 6th 04 05:03 PM
Monarch fuel caps Javier Henderson Owning 1 January 12th 04 06:48 PM
