Phoenix airport [40/44] - DSC_4048.jpg (1/2)
Old December 17th 10, 02:04 AM posted to alt.binaries.pictures.aviation
Morgans[_2_]
Default Phoenix airport [40/44] - DSC_4048.jpg (1/2)
To the OP of this group of pictures:
You need to get the file size you upload reduced down to a couple hundred
kb, or many people like me will not be bothered enough to look at your
pictures.
Old December 17th 10, 06:21 PM posted to alt.binaries.pictures.aviation
Indrek Aavisto[_4_]
"Morgans" wrote in message
pictures.
Hmm, the vast majority of the pictures were under 200 kb, though a couple
did go over that. I don't think most people would have a problem with that.
However, you are at liberty to ignore the larger files if you wish.
Cheers,
Indrek Aavisto
Criticism is easy; achievement is difficult W.S. Churchill
Old December 17th 10, 11:38 PM posted to alt.binaries.pictures.aviation
Morgans[_2_]
"Indrek Aavisto"
that. However, you are at liberty to ignore the larger files if you wish.
The problem is that they are multi part, when they don't need to be so large
that they become multi part.
Get the whole picture down to a couple hundred k so they can be one part;
that is the key.
Old December 18th 10, 02:25 AM posted to alt.binaries.pictures.aviation
Indrek Aavisto[_4_]
"Indrek Aavisto"
large that they become multi part.
that is the key.
OK Jim, thanks for the clarification.
I have since increased the number of lines that Powerpost 2000 uses as the
the point at which it breaks an image into parts. That should solve the
multi-part issue. As for the absolute file size, I compress my images to
1000 pixels wide which usually results in file sizes in the 100 to 200 kb
range. However, if the picture has a lot of fine detail the overall file
size does tend to go up beyond that.
Cheers,
Indrek Aavisto
Old December 18th 10, 03:25 AM posted to alt.binaries.pictures.aviation
Morgans[_2_]
Thanks for that. I hope it works for both of us.
I don't have a problem with slightly larger file sizes. I have a problem
with having to combine multi part posts that are unnecessary.
I look forward to seeing more of your pictures.
Phoenix airport [12/44] - DSC_3745.jpg (1/1) Indrek Aviation Photos 0 December 17th 10 12:59 AM
Phoenix airport [44/44] - Phoenix Airport Index 4.jpg (1/1) Indrek Aviation Photos 0 December 17th 10 12:58 AM
Phoenix airport [43/44] - Phoenix Airport Index 3.jpg (1/1) Indrek Aviation Photos 0 December 17th 10 12:58 AM
Phoenix airport [42/44] - Phoenix Airport Index 2.jpg (1/1) Indrek Aviation Photos 0 December 17th 10 12:58 AM
Phoenix airport [41/44] - Phoenix Airport Index 1.jpg (1/1) Indrek Aviation Photos 0 December 17th 10 12:58 AM
